I have a PCB which has a 0.010uF X2 safety capacitor fitted. It seems the exact part is now obsolete.
Would it be acceptable to replace this part with a 0.010uF X1 safety capacitor?
I believe a capacitors subclass is decided according to its peak/rated and impulse voltages. With an X1s ratings surpassing those of the of X2 and X3.
I know I could probably find another 0.010uF X2 to replace it.
I also know I have not provided much information about the overall application. Which is because it's ancient and I have limited supporting documentation (typically).
313Ctron
  • 57
  • Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. – Community Sep 17 '21 at 08:25
    Yes, that's fine. X1 has higher voltage withstand. – winny Sep 17 '21 at 08:55
I also found the following slide provided by KEMET. Might be useful as it references Y capacitors too...
313Ctron
  • 57
X1, X2 and X3 voltage ratings: -
Picture from here. Same info; different source: -
Image from here.
Regarding voltage ratings, X1 has better specifications.
