a) Suppose a binary pick-up adder (carry-select) of 32-bits, comprising 4 sub-sections adders spreading carry of range 8 bits. Show the values obtained internally in the circuit of this adder to perform the addition of the numbers 01011001101100111110110011001101 and 10010110011111000001101100110110. Specifically, show the input and output values on each 1-bit full adder circuit, as well as the input and output values on all multiplexers in the circuit. If each complete 1-bit adder circuit and each multiplexer circuit cause a delay of 2T in the execution of the operation, where T is the delay time of an elementary gate, find the calculation time of the retained output.
b) Repeat the above if the 32-bit adder includes 6 sub-sections adders spreading carry, ranging in order from less to more important sections 2, 4, 4, 6, 6, and 10 bits.
The idea of that method is :
The adder is divided into two halves of equal length. And for both halves, the addition is started at the same time. In the left (more significant) half we don't know whether the carry input of the rightmost full adder is a 1 or a 0. Therefore, we do the addition of the left half twice at the same time, once with a 0 at the carry input and once with a 1. If the right half with its addition is done, we know the incoming carry of the left half. So we know which of the results is the right one, which we then select (select). The other (wrong) result is simply discarded.
Is that correct?
So we split 01011001101100111110110011001101 into a_1=0101100110110011 and a_2=1110110011001101, right?
And we split also 10010110011111000001101100110110 into b_1=1001011001111100 and b_2=0001101100110110, right?
Then we add a_1+b_1 wih carry 0 and a_1+b_1 wih carry 1.
We also calculate the addition a_2+b_2.
As for the addition a_1+b_1 wih carry 0 : $$0101100110110011+1001011001111100=1111000000101111$$
As for the addition a_1+b_1 wih carry 1 : $$0101100110110011+1001011001111100=1111000000110000$$
As for the addition a_2+b_2 : $$1110110011001101+0001101100110110=0000100000000011\ \ \text{ with carry } 1$$ So we select the second case of a_1+b_1.
Is everything correct?
How could we continue?
