I have a 12V 10W solar panel that I'd like to use to charge a power bank (USB input). Here are the stated characteristics: V(max power) = 19.5V, I(max power) = 520mA, V(open-circuit) = 22.5V, I(short-circuit) = 550mA. I have some questions about the 'power conversion' that I'm trying to work out.
I connected a LM2596 based buck converter module (12-40V input to USB output) to the panel and connected the power bank to the buck converter via a USB cable. In full sunlight I was able to get a output current of about 400mA with an output voltage of 4.75V from the buck converter. This is barely 2W! The panel voltage falls to about 9V at this point. Please help me understand why this happens.
Is the buck converter trying to draw too much current/power and the panel cannot keep up, which in-turn causes the panel output (both voltage and current) to drop far below expected? Is the panel simply not 'producing' that much power while still being in full sunlight? It just doesn't make sense to me intuitively. I have tried to understand the I-V curves and MPPT point but I guess I'm not able to keep up very well with those either.
  1. Is the solar panel not working like a 'battery'? If not, what do I need to understand about its working?
  2. What would be the best way to achieve my purpose here without causing massive power losses?
Appreciate your help!
  • Does this answer your question? [Solar panel voltage drops when connected with load](https://electronics.stackexchange.com/questions/531556/solar-panel-voltage-drops-when-connected-with-load) – ocrdu Sep 14 '21 at 08:38
  • Thanks @ocrdu, it answers my first question about the working of a panel. For the second question, the best way to get maximum out of conversion to 5V USB, what would be the most optimal (power-wise) solution? Also, if there is a not-so-optimal but cheaper solution. – Aashish Sharma Sep 14 '21 at 08:46
    Maybe this helps? [Understanding working of MPPT charger](https://electronics.stackexchange.com/questions/519900/understanding-working-of-mppt-charger/) – ocrdu Sep 14 '21 at 08:52
  • I would say the buck converter is probably not doing MPPT unless it's designed for that. – user253751 Sep 14 '21 at 09:02
0 Answers0
