Is it possible to control a NEMA Stepper motor directly from an FPGA without a separate Motor Driver Circuit?
I have the following setup:
The pins that the motor is connected to provide 3.3v and the FPGA has been programmed in Verilog to step a sequence of 'phase' changes.
My question really comes down to:
  • Is this possible?
  • Do I need to provide a higher voltage than 3.3v ?
  • Do I need a separate controller circuit, if so, why?
TinyFPGA to NEMA
nthState
  • 71
    https://www.pololu.com/product/2966 – Jerry Coffin Sep 13 '21 at 03:21
    3.3v is not the problem (though read your motor spec sheet to know what voltage it was designed to run at). The problem is the motor consumes a huge amount of current. This is like asking can I use a tap to control a river? -- no, you need a dam – slebetman Sep 14 '21 at 03:17
  • This is the best abuse of the plumbing analogy ever! Love it. – johnnymopo Oct 13 '21 at 01:28
No. Just like a microcontroller, an FPGA pin will provide nowhere near enough current to drive a motor.
If you're lucky you might get 20mA out of an FPGA pin, in practice most I've come across are limited to much less than that (2-8mA range). Looking at the datasheet, yours appear to be rated for +/-8mA output current. Your stepper motor will require orders of magnitude higher currents. Trying to drive the stepper directly from the microcontroller will at best do nothing and at worst fry the IO pin.
That's also before you even start considering the inductive kickback you'll get from the motor. High voltage spikes from switching the inductive load will certainly fry the ESD protection on the IO pin.
You will need some form of stepper motor driver which takes a 3.3V logic level input (e.g. one of the Pololu stepper breakout boards) and a suitable power supply.
Tom Carpenter
  • 63,168
  • 139
  • 196
  • Thanks for the info! I don't have enough reputation to vote up – nthState Sep 12 '21 at 18:33
    You can probably fry the FPGA pins just by turning the NEMA motor shaft, the way you have it wired up in the piccture. (In case you thought you were safe because nothing is plugged in to power.) – DMPalmer Sep 13 '21 at 21:54
No, not possible to drive motors directly from an FPGA.
The FPGA IO pins are logic level signals. While perhaps they can be quite strong for logic level signals, they are not strong enough to provide anywhere near the required current to drive a motor.
Most likely the motor needs higher voltage to operate as well.
Justme
  • 127,425
  • 261
