I got 4 16GB 2Rx4 PC3-14900R memory chips; Samsung M393B2G70DB0-CMA
Out of 4 memory sticks, 1 OK, 2 report ECC errors (correctable - 1bit), 1 dead.
I would like to replace the damaged chips. There are 36 of memory chips on a memory stick and I don't know which one is damaged. How do I identify the damaged chips?
This is the memtest86 error message.
Memory Range Tested 0x200000000 - 240000000 (1024MB)
2021-09-04 19:19:28 - [ECC Error] Test: 5, (Rank,Bank,Row,Col): (N/A,N/A,N/A,N/A), ECC Corrected: Yes, Syndrome: N/A, Channel/Slot: 5/0
aditional sugestion I had found over internet says that is not easly possible without specialized eq https://www.edaboard.com/threads/dimm-testing-is-there-any-solution.361390/
