I came across an answer about the construction of a multilayer board. It included an image showing the mechanical construction of a board (see image 1.)
This prompted me to think of the actual construction a bit more.
Image 1: Construction of multilayer board
The image shows the through hole and via pouring in between the layers. Is pouring into a gap really what happens or is it just some artistic freedom on part of the image creator? Is the shape of the hole really ribbed? I mean it would make sense to make construction more connected, but it also makes sense for the author to emphasize the effect. Equally plausible would be that some manufacturers do this some don't. Is there any practical stack design where there would be internal ribs?
What I'm asking is the last copper buildup like:
The image seems to suggest A because there is a line between the copper layer and hole.
Also something that the image does not show is what is filling the gap between the layers where there is no copper.
Null
  • 7,448
joojaa
  • 203
    Just to clarify, what precisely is the “this” you’re referring to when you ask “is this what really happens”? Are you asking whether vias actually exist? – Sneftel Sep 02 '21 at 08:57
  • @Sneftel no im asking does the via actually form a cylinder or does it actually form a ribbed structure like in the picture – joojaa Sep 02 '21 at 09:05
    If you are asking "if i cut a real PCB in half, what will i see?" then yes, picture is very close to reality. – Morris Sep 02 '21 at 09:06
  • @Morris Well the only PCB i have that could be sacrificed didnt actually address the actual question. IE is the copper grown on a cylinder or ribbed structure. Also it does not tell what they use for leveling the surfaces. But that may be because i don't have enough magnification and or didn't polish surface enough. – joojaa Sep 02 '21 at 09:08
    The "ribs" are the individual copper layers and what's between them is just fiberglass FR-4 or similar. – Lundin Sep 02 '21 at 09:11
  • @Lundin yes but the image shows that there is a cylinder with ribs and then a separate layer. So when manufactured the clylnder gets made separately form the layer. But the image clearly shows that there is a component of the cyliner that pours in between the layers. So my question is does it really do that. – joojaa Sep 02 '21 at 09:14
  • IIRC, "ribs" are always present - via making process just works this way. I may be wrong, though. – Morris Sep 02 '21 at 09:16
  • @Morris ok then thats the answer. How does the gap form is it made on purpose by the etchin process? – joojaa Sep 02 '21 at 09:20
    The rib doesnt "pour", its already there from the inner layer sheet of copper. In the copper deposition process you build the cylinder inside the ribs. Here some nice images: https://www.google.com/search?q=PCB%20cross%20cut&tbm=isch&tbs=rimg:Cb1_1c8k2Wv71YeFhL_1_1makfH&hl=en&sa=X&ved=0CAIQrnZqFwoTCMiYqYv93_ICFQAAAAAdAAAAABAC&biw=1405&bih=1206 – Wesley Lee Sep 02 '21 at 09:31
    Either A or B are achievable with a standard (through via) process : to get B, delete the pads around the vias on the inner layers, unless you are routing signals to that via on that layer. Use a Gerber viewer on each layer to see what you'll actually get. –  Sep 02 '21 at 11:43
  • The [fourth image](https://web.archive.org/web/20210903002927/https://www.multi-circuit-boards.eu/fileadmin/_processed_/c/8/csm_10-lagen_leiterplatte_microsection_ae5a41c25a.jpg) from the link that @WesleyLee provided is particularly good. On the image you can see that the interior layers don't align perfectly (the rings are offset from layer to layer). Makes it pretty clear that the rings are etched from each layer's copper, not grown outwards from the vias. – Alex Hajnal Sep 03 '21 at 00:36
You've got several parts to your question.
Those parts are represented by the red, blue, and green arrows I've added to the drawing:
The blue part references what's between the layers where there's no copper.
PCBs are manuafactured from sheets of fiberglass matts and epoxy. Each layer is a premade sheet of fiberglass and epoxy with a sheet of (thin) copper on the top and bottom of the sheet.
The copper is etched to make the traces on the top and bottom of the layer.
When a multilayer PCB is assembled, the fabricator stacks up several of those sheets and lines them up carefully so that all the traces and other details line up.
There is a thin coat of epoxy between the layers. The whole stack is put under pressure (clamped flat together) until the epoxy is cured (hardens) so that the stack will stay together.
Between the layers is (at most) a very thin layer of epoxy. The fiberglass is "mashed" into the open areas around the copper by the pressure. Any open areas where the fiberglass can't reach (closest around the traces) will be filled with epoxy.
The red arrows indicate the "ribs" where the vias go through each layer.
Vias are made by drilling holes through the finished stack after the epoxy has set. The vias are then plated with copper. The copper plating in the holes joins all the copper layers together.
The PCB design software will include "rings" of copper on each layer to make the noted "ribs." The assembly process doesn't leave little gaps for the copper plating to spread out and make the "ribs." The "ribs" must be in the etched copper layer. When the through holes are plated, the rings specified by the design software are joined to the plated hole to make the "ribs."
The line indicated by the green arrow is somewhat misleading. That line appears to mark the boundary between the plating that make the through hole and the copper plating on the surface of a layer of fiberglass. The line would more properly be in the place marked in purple (just to the left of the green arrow.)
Speculation about the "ribs."
I don't know that any manufacturer requires adding the ribs. As far as I can tell, they are added by the PCB design software when placing the vias.
The Eurocircuits guidelines for making PCBs specificall says to remove the pads on any inner layer that you don't want connected to the through hole plating. That means the "ribs" aren't a required part of the manufacturing process.
Eurocircuits has a nice series on the construction of PCBs, describing the individual manufacturing steps. Each section in the series has a description with pictures and a video of the process.
To answer the additional question posted in the comments, the plating looks like "B" in the image below:
The "rings" in "A" are on the fiberglass layers. The plating goes inside the hole and over the surface of the top and bottom layers of the stack.
JRE
  • 67,678
  • 179
  • Yeah you have described the process as i understand it. But it seems this a is abit of a does not translate betyween cultures question. See im a mechaanical engineer. In a mechanical drawing having a line between 2 things means there is a separate piece or separate process so what im asking [what does the last buildup of copper look like linked picture](https://i.stack.imgur.com/mrC95.png) – joojaa Sep 02 '21 at 09:53
  • Thank you. So what your saying is that the image is a bit misleading in constructions there should be no line between the copper layer and the through hole – joojaa Sep 02 '21 at 10:04
  • The ribs appear to be purely something that the design software does, and is **not** required by the PCB manufacturing process. Eurocircuits says you can leave them off, and doesn't mention any possible negative effects. – JRE Sep 02 '21 at 10:16
    @joojaa Yes, JRE is saying the image is a bit misleading: the line should be where the purple line is - unless the intention is to show "this is the via" and "this is the trace" (if you consider the rings to be part of the via) – user253751 Sep 02 '21 at 11:03
  • in Altium you can remove these 'ribs' with Tools->Remove unused pad shapes. Useful for ultra dense boards, or if you want to free up a bit of extra copper on your power planes. – Ocanath Sep 02 '21 at 19:00
    I believe that a layer of epoxy-impregnated fiberglass ("prepreg"), rather than just plain epoxy, is used between layers - epoxy alone wouldn't make a very reliable separation between copper layers. – Peter Bennett Sep 02 '21 at 19:53
  • After the drilling of vias, I assume the via plating process is some sort of deposition of copper, that fuses at a molecular level with any copper freshly exposed by the drilling. Is that correct? Or are the plated through-holes some kind of copper rivet, with only mechanical contact to the exposed copper planes? – Simon Fitch Sep 03 '21 at 04:13
  • @PeterBennett, I'd go one step further and say that (in one common type of stack up), every other layer is a pre-preg layer, and therefore it simply epoxies itself to the core layers it's sandwiched between. (Meaning, there isn't a prepreg placed between two adjacent layers, the prepreg is itself one of the layers) – The Photon Sep 03 '21 at 04:29
  • @SimonFitch. The copper in the via is deposited by a chemical plating process. This generally also leads to thicker copper on the outer layers than was initially there. – The Photon Sep 03 '21 at 04:30
  • How do you make a buried via without it getting filled with epoxy? – OrangeDog Sep 03 '21 at 07:49
  • Would the presence or absence of annular rings on inner layers have any effect on the mechanical strength of a plated throughhole? – supercat Sep 03 '21 at 15:27
  • @supercat: It should, but I couldn't tell you by how much - or even if it is noticeable. – JRE Sep 03 '21 at 15:38
  • It's never used for multilayer boards, but you also see the odd PCB made using phenolic paper (FR-2) instead of fiberglass (FR-4). It's just a cheaper material; as far as I know, it's inferior to FR-4 in every way other than cost. – Hearth Sep 04 '21 at 15:38
The copper sections should all be connected -- the lines in the original diagram are not meaningful in terms of the resulting structure. Here's an updated diagram with fewer lines: enter image description here
Justin
  • 5,944
  • @csstudent1418 In this example they are all connected, for the purpose of demonstration. This is just showing how vias look though. A real circuit wouldn't need to use three vias in this arrangement. – user253751 Sep 03 '21 at 20:17
The distinction between the via, its annular ring, and the copper trace or layer is somewhat arbitrary. It's all continuous copper.
The graphics are showing the vias using the abstraction with which you'll work with them in your PCB software. The ribs or rings are defined by the annular ring diameter property, the presence of connecting copper is defined by the trace or plane structures that you may or may not connect to the via. Often, the trace or plane extends all the way to the center of the via where it gets drilled away, and it's purely for eye candy that you don't see this in your PCB editor; you can see it in some generated Gerber layers.
However, mechanically, the assembly order is:
  1. Fiberglass sheets are covered with copper foil to form the inner layers
  2. Some copper is etched away where you don't want a trace or plane; eg. a circular void is added to the foil where a via that you don't want to connect passes through.
  3. Fiberglass sheets and the inner etched copper sheets are stacked and epoxied together
  4. Vias and plated slots or through-holes are physically drilled through the stackup. The hole edges are deburred at the surface and desmeared to ensure no epoxy resin is left on the exposed inner layer copper.
  5. Copper plating is added to the entire exposed surface of the board, which now includes the walls of the holes and the 25 micron thick visible rings from the inner layer connections. The deposited copper makes the finished hole slightly smaller in diameter than the hole that was drilled in the fiberglass
  6. The surface copper is etched away as the inner layers were etched in step 2
  7. Non-plated through holes, soldermask, silkscreen, V-groves, board edge milling, and so on are later added.
The copper layers are built up and removed by chemical deposition, chemical etching, and physical drilling into a continuous 3D shape of copper. In the end, there should be no seam. If you were going to draw one you might make a distinction between the plated hole walls and the surface of the layers where you might have a failed deposition if contaminants get inside the hole before it's plated.
johannes
  • 223
