I have been using a DSPIC30f4011 for two days but suddenly I am no longer able to program the chip again.
The message I am getting:
Failed to verify at programming address 0x0000 (when I click the Verify button).
Failed to program at programming address 0x0000 (when I click the Write button).
Successful (when I click Read button).
Successful (when I click erase button).
I clicked on the erase button and tried to get rid of the error. But when I clicked read after erasing it, the first byte is still 0000 0000. Everything else is FFFF.
I am pretty sure the wiring and power supply is correct because when I put a new chip into the spot where the old chip was at, PICKIT 2 is able to program/verify it.
The pickit shows All protect for both old chip and new chip so it's not a problem.
Timtianyang
  • 521
  • If you can erase it then what is read? Also what voltage are you running – Grady Player Feb 19 '13 at 03:25
  • Also do you have the code protection set in the config? – Grady Player Feb 19 '13 at 03:26
  • @GradyPlayer The erase is not working. Every time read will return the same thing after the chip is erased. I am running at 4.7 V. I never enable code protect. Another new chip is doing the same thing to me. – Timtianyang Feb 19 '13 at 15:06
  • I was having the same thing yesterday with a 16f884, after pulling my LEDs out, and reprogramming once at 5v then unchecking erase before program I was able to reprogram... After reading that whole chip erase needs 5v – Grady Player Feb 19 '13 at 17:12
  • Yeah, I do have several LEDs connected to the chip when it is being programmed. But unplugging them doesn't solve the problem. Thanks though. – Timtianyang Feb 19 '13 at 21:28
  • well unplugging the leds was only to allow me to bump the voltage to 5.0 from 3.3 without changing resistor values or burning them up. – Grady Player Feb 19 '13 at 22:07
  • What happens when you do a blank check after an erase? – mjh2007 Apr 29 '13 at 18:57
AVDD and AVSS must be connected.
Timtianyang
  • 521
  • Was this responsible for the issue you were having? – rdtsc Feb 05 '16 at 12:54
  • yes. At least for the chip I'm using, as soon as they are connected the issue is gone. page 12 of the datasheet: "This pin must be connected at all times." – Timtianyang Feb 05 '16 at 18:50
The device is probably faulty.
Leon Heller
  • 38,774
  • 60
  • 96
If you attempt to erase a device and then perform a blank check on it and the blank check fails there’s a chance that the flash memory on the IC is bad. Flash memory based devices only have so many erase / write cycles that can be performed on them before they burn out.
mjh2007
  • 3,899
  • 49
