I'm looking at purchasing an item which is marked as faulty, the female usb port was damaged and the owner, following a tutorial attempted to replace it themselves. They clearly could only get so far as the item is now listed as for sale.
What I want to know is whether or not this circuit board is damaged beyond the point of repair? I would quite like to take up the task of the repair myself but don't want to back a losing horse. Thanks
damage in bottom right
    We don't know your skill set to answer if it is beyond repair for you. Can you find a suitable connector? There is also no copper traces left onboars to solder a connector, so it might require rewiring the USB connector pins with small wires to suitable places. If that's a $120 Yeti USB mic, think if buying the tools necessary and time to repair is still less than $120 after purchasing a damaged mic. – Justme Aug 24 '21 at 16:26
    If you have good fine-motor skills, a bit of experience soldering and a good soldering gun, this actually is "pretty easy". I could knock this out in about 15 minutes. If you've never soldered before, honestly just forget it. There's a reason the previous guy weinered it so badly. – Kyle B Aug 24 '21 at 16:28
  • I wouldn't even attempt to repair it. This item has exactly 0$ value. – Marko Buršič Aug 24 '21 at 17:07
The soldermask and traces are badly destroyed around the USB port, and all that can be seen are through-holes that have likely lost their plating as well.
You may be able to follow the traces back to the next component where they ran to - it will take some reverse engineering to confirm this, but an initial guess can be made based on knowledge of how USB is typically wired.
According to this post, we would expect that USB ground and power run up to C35 and then the ferrite beads L2/L3 (although it could be USB ground and cable shield ground as well, you'll need to confirm). Some work with a continuity tester and figuring out which pins are supply pins of various chips would help to confirm this.
Meanwhile, USB data probably runs to the right (in the point of view of the second image) to R2/R3 which are likely the series termination resistors.
If you have a steady hand, some extra USB cable with the right twist in its data lines, and tools suitable for soldering wire onto the existing pads of those surface-mount capacitors and resistors without creating more damage, you may be able to connect a USB cable to the board. Mechanical strain relief will be necessary as well as a solder connection to the pads will not handle any meaningful tension on the cable.
nanofarad
  • 18,062
  • 47
  • 73
