You can on the label that the motor requires 230 volts at 50 Hz AC power. It also requires a 3 microfarad capacitor that is rated 430 volts AC. The capacitor value compared to the 0.8 amp motor current requirement indicate that the motor is a single-phase motor of the permanent split capacitor (PSC) type. If the capacitor is not attached to the motor, you need to obtain a suitable capacitor and determine how it should be connected. Since there are only 3 wires coming out of the motor, you know that it must attach to two of those wires. Power needs to be connected between one of those two wires and the third wire.
If the plug that is connected to the motor is the type that plugs into the wall, and it was connected by someone who knew the proper connections, one of the three wires must be an earth/ground wire that is connected to the motor frame. The other two wires should be connected to the motor windings. The capacitor is either already attached or there is an attachment point that you have not discovered.
If the plug is the type that interconnects components inside an appliance, they all connect to the motor windings and the capacitor was attached somewhere inside the appliance from which the motor was removed.
The motor speed can not be controlled very satisfactorily. There are other answers to questions here that explain that. here is one of them: Speed control for PSC induction motor
