is it possible optocoupler EL817 wiht input 3.3VDC and output 24VDC like below circuit. and if it possible what is the suitable value for the resistor
Asked
Active
Viewed 187 times
1. EL817 output is not strong enough to directly drive a buzzer. The usual trick is to first drive a BJT which is strong enough to in turn to drive a relay switch (or a buzzer). You might like to skim the following post to get a rough idea on the EL817C/NPN BJT biasing design. 2. If you are going to use a BJT for EL817C, you might like to show your circuit so everybody can help. Cheers. Ref: https://electronics.stackexchange.com/questions/505318/how-to-properly-use-a-relay-module-with-jd-vcc-from-arduino-raspberry. – tlfong01 Aug 12 '21 at 01:34
1Why would a buzzer need opto-isolation and what current is this? – Tony Stewart EE75 Aug 12 '21 at 01:53
2please stop shouting. – Hearth Aug 12 '21 at 02:21
1@tlfong01 okey i will upload full schematic after it finish. – Rizkis Walker Aug 12 '21 at 05:53
1@TonyStewartEE75 in this case i want to switch on the buzzer by give 24VDC – Rizkis Walker Aug 12 '21 at 05:54
If you have a 3V3 signal, say, from a GPIO pin, you can directly drive an active buzzer (Eg, using 4k7 for the front end BJT,, without using any optocoupler. There is also a demo program to beep the buzzer.) Reference: Active Piezo Buzzer Makes Sound On Both Rpi GPIO Low and High Level Signal Asked 2 years, 3 months ago Viewed 3k times. https://raspberrypi.stackexchange.com/questions/97980/active-piezo-buzzer-makes-sound-on-both-rpi-gpio-low-and-high-level-signal. – tlfong01 Aug 12 '21 at 08:57
24Vdc is not a current and buzzers if plastic insulated do not need opto isolation – Tony Stewart EE75 Aug 12 '21 at 10:37
@TonyStewartEE75 sorry buzzer spec is : 20mA 24VDC – Rizkis Walker Aug 13 '21 at 00:45
