I'm wondering what factor determines the maximum output current of a power bank. Is it limited by the internal battery's current or the output current of the voltage regulator? Also I'm not sure that all of the power banks have a voltage regulator for their output. The maximum output current of the typical power banks is around 2.5A but it can goes up to 4.8A.
Asked
Active
Viewed 311 times
1For both, Internal resistance -> heat or voltage drop. Weakest link. – DKNguyen Aug 11 '21 at 00:52
1The maximum output current is determined by the designer and that person picks the appropriate parts to accomplish his requirements. You are probably correct I would also assume all do not have a regulator. From your links this difference is easy to see. You will have to research each power bank you are interested in, there is no set of rules they follow. – Gil Aug 11 '21 at 01:31
@DKNguyen Do you mean both of them could be the limiting factors? – S.H.W Aug 11 '21 at 11:39
@Gil Thanks. Do you know any specific reference which shows the calculation for the maximum output current of a power bank? – S.H.W Aug 11 '21 at 12:03
1Internal resistance causes both heat and voltage drop. One of the two will become a problem first depending on system details. – DKNguyen Aug 11 '21 at 13:16
1That would have to come from the manufacturer of the power bank. You can disassemble one, reverse engineer it and then do the calculations or you can test the capacity if your interested. – Gil Aug 11 '21 at 17:41
