  • There are a few 6pin and 10pin pogo variants of Atmel ISP adapters that require dedicated ISP pogo pads on the PCB.
  • There are full TQFP-32 ZIF sockets that can be used to program any AVR in that package, but it needs to be done before soldering to the PCB.
However, there is something like a pogo connector that goes directly over the TQFP-32 package (after it was soldered to the PCB and doesn't require dedicated ISP pogo pads) and has a pinout that allows the mega8/mega88 (and probably some other AVRs which have ISP on the same pins) to be programmed with ISP. I had one in the past and I know it exists. But no matter how I'm searching for it I fail to find it. Does anybody know how it's exactly called or where to buy it? On the other side, it ends with a ribbon cable and ISP 10 female pin header socket.
The adapter looks something like this: https://www.youtube.com/watch?v=t5unHRB2sV4
But can't find anybody selling it, I think before it was all over the ebay.
Anton Krug
  • 135
Hobbyking used to sell them, but it's been discontinued apparently. It looked like this:
You could search to see if anyone still has it in stock, or if you have access to a milling machine with a DRO and a handful of one of the smaller sizes pogo pins it would not be hard to duplicate the business end from a small chunk of acetal plastic or other suitable material and solder a cable with heat shrink onto it. The TQFP is fairly crude at 0.8mm lead pitch so it does not require the skills of a master machinist.
Spehro Pefhany
  • 376,485
  • 842
