I want to know about wire loss per meter. However, in the datasheet, it is written that 6.1 dB is attenuated per 100 meter, so I wonder if it is possible to simply calculate 0.061 dB if I want to calculate with 1 meter.
If it is possible or impossible, I wonder why?
Mitu Raj
  • 10,843
journey
  • 119
    Yes it is 0.061 dB/meter. – winny Aug 06 '21 at 06:31
  • @winny do losses add linearly - i.e. if a 100m cable has 6.1dB attenuation, will a 200m cable have 12.2dB? – Justme Aug 06 '21 at 06:35
    dB add linearly. But dB is not a linear scale, of course. It is logarithmic. – user57037 Aug 06 '21 at 06:57
    This is thoroughly covered by Wikipedia search Wikipedia decibel – RoyC Aug 06 '21 at 06:59
  • `These quantities are to be manipulated obeying the rules of dimensional analysis, e.g., a 100-meter run with a 3.5 dB/km fiber yields a loss of 0.35 dB = 3.5 dB/km × 0.1 km.`-- Wikipedia for 'decibel', section 'Fraction'. – Mitu Raj Aug 06 '21 at 07:07
    I am not questioning whether decibels add linearly because they do; rather, I am questioning if losses in a real world electrical cable add linearly or not, are there extra losses somewhere? I.e. does a 50m cable have less that 3.05 dB loss and 200m cable more than 12.2 dB loss, if a 100m cable has 6.1dB? – Justme Aug 06 '21 at 07:57
    @justme they add linearly. If 100m has 6.1 dB, then it follows that 50m will have 3.1 dB and 200m will have 12.2 dB. Connections will also have losses. Conversions from one type of cable to another, bulkhead fittings, etc. This is called "insertion loss" and would be added to the sum of total cable losses (in dB). – user57037 Aug 06 '21 at 08:07
  • @Justme think of them as un-lumped attenuators. The whole point of using dB is that you can put two 3 dB attenuators one after the other and get 6 dB of attenuation. Same deal if your attenuator is a 100 m cable. – llama Aug 06 '21 at 20:27
Losses (or gains) multiply. This leads to the convenience of using a log measure dB for them, which add.
So yes, 6.1 dB per 100 m is 0.061 dB per metre.
Note that there are additional discontinuity loss terms if the cable and the measurement system are mismatched in impedance, the larger the mismatch, the larger the error. These errors could easily be bigger than 0.06 dB. Only try to estimate the loss of a cable by measurement by measuring a long length, short lengths could be proportionally very wrong.
100m of cable would measure 6.1 +/- discontinuity_loss dB.
200m of cable would measure 12.2 +/- discontinuity_loss dB.
50m of cable would measure 3.05 +/- discontinuity_loss dB.
1m of cable would measure 0.061 +/- discontinuity_loss dB.
... where discontinuity_loss depends on any cable mismatches, connector repeatability, precise length of cable (due to the phase that the two end reflections add up) and the order of length of cable (as the cable loss increases between the two ends, the two ends interact less). It's good when making a measurement of insertion loss to sweep the frequency over sufficient range to alter the electrical length of the cable under test by at least λ/4, this will swing the combination of discontinuity_losses from each end of the cable over its maximum and minimum values, allowing you to assess whether they are significant or not.
Neil_UK
  • 158,152
  • 173
  • 387
