The cable you have linked to is a 4-core double-insulated cable. That's suitable for outside the panel.
Figure 1. 0.75 mm2 hookup and equipment wire. Image source: RS.
Your panel is showing single-insulated panel hookup wire. This is multi-strand for flexibility. Strand packing is usually done in 1 (single-core), 7, 19 strands, etc. which gives the best packing without gaps.
Stranded cables work will all common terminals including screw clamp, cage clamp (below) and can be pin-crimped.
Figure 2. Wago cage-clamp terminals.
Some of the terminals require a 'just right' screwdriver to release the cage properly. (Some screw terminals require the right tool too.)
Figure 3. Cage clamp and wire showing excellent contact area.
For 20 A you should be considering 2.5 mm2 or 4 mm2 hookup wire.
(Photos used previously in my answer to another question.)
