I am trying to make BLDC driver with IR2101. MOSFETs I am using are IRFB4110PBF.
So for testing I am currently using one pair. I am using oscilloscope to see the output waveform. What I see is that it always remain high as soon as I attach power. Turns out voltage at HO stays high and at LO stays low, doesn't matter if I attach input pins or not. I come to know that IR2101 bootstrapping needs continues pwm to work so I tried giving square wave of 500 Hz on input. Vcc is 10V.
If I apply voltage on LIN, that should output 0 V, right?
Am I using the right way to check or there is something I am missing. How you check if IR2101 is working properly?
I am using below mentioned schematic. If any more info require please let me know.
I tried to change gate resistor to 10 ohm, main supply capacitor to 100 uF and 10 uF, added diode parallel to gate resistor for fast discharge, nothing helped.
Thank you.
