62
This video shows a 9-volt battery connected to a wire as a primary.
The first reason I think this is fake is that he is powering a Tesla coil with 10 volts.
The second reason is that Tesla coils work on AC, or at least I thought so, and he wouldn't be able to step the voltage up too high because a transformer only works on AC and the battery provides DC.
MicroservicesOnDDD
  • 2,557
Gabriel ashmore
  • 691
    The transistor + feedback winding can work as an oscillator. – Unimportant Jul 27 '21 at 03:38
  • Use a Lithium 9V cell – Tony Stewart EE75 Jul 27 '21 at 03:54
    DC is DC, but you can run DC through switches to make it constantly change the direction that it flows into/out of another circuit which turns it into a form of AC as far as that circuit is concerned. – DKNguyen Jul 27 '21 at 04:17
    Who has a schematic? https://tinyurl.com/yjzmeypv. https://tinyurl.com/yj3up6pm – Tony Stewart EE75 Jul 27 '21 at 04:59
    Regarding the other thing going on here - a fluorescent bulb being powered wirelessly, I can attest to that definitely being a thing. I grew up half a mile away from some overhead power lines, and you could take a fluorescent bulb (in those days just the straight tube kind) and bring it near the power lines (and by "near", I mean, just on the ground 100 ft. below them), and they'd glow very nicely. – Darrel Hoffman Jul 27 '21 at 13:32
    Not only that this is not fake, you can get one for less than 2 dollars online from China. – Hanky Panky Jul 28 '21 at 06:43
  • Can anyone tell me if this work with a tungsten bulb?? Is it completing the circuit via earth or something? – Meenie Leis Jul 29 '21 at 06:21
    @MeenieLeis It wouldn't work with a tungsten bulb. It works on the fluorescent bulb via a rapidly changing magnetic field. – evildemonic Jul 29 '21 at 13:40
    @evildemonic So there is no flow of electricity here in the fluorescent bulb? It's just the material physics. – Meenie Leis Jul 31 '21 at 07:16
    @MeenieLeis Electricity is flowing in a sense, but it is not completing a circuit like you would imagine. Look [HERE](https://physics.stackexchange.com/questions/402421/how-exactly-does-a-tesla-coil-make-fluorescent-light-glow) – evildemonic Jul 31 '21 at 15:05
It's real.
this video shows a 9-volt battery is connected to a wire as a primary
... and a transistor, and a resistor.
This is the simplest SSTC (Solid State Tesla Coil) I've seen. The transistor chops the incoming DC power supply so that it's changing at the primary. It takes feedback from the secondary, so that it oscillates at the resonant frequency of the secondary inductance and its self capacitance.
Drawing the circuit from the video (I might make one myself for the lols), we get this
I'm not absolutely certain I have the transformer 'dotting' correct, but I think I have interpreted it correctly from the video. If it fails to work, swap the orientation of one of the coils. Eye-balling the coils, I'd guess at 32 mm x 100 mm and 200 turns = 350 µH for the secondary, and 35 mm x 3 turns = 690 nH for the primary, coupling in the 0.1 to 0.2 ballpark.
When power is switched on, the transistor is biassed as an amplifier by R1. It's quite a large value, so the base current is small, and the collector current is similarly small enough that the transistor doesn't draw too much current for the battery or let out smoke.
If you run this in a simulator, that might be all that happens until you give it a kick. In real life there's noise in the circuit, and this noise will be amplified by the transistor. This will cause a variation in the collector current, which will induce a voltage in the secondary. This voltage will drive a current into the circuit consisting of the transistor base and the coil self capacitance. If the transformer is connected the correct way round, the effect will be to reinforce the change and drive it further.
This reinforcement will continue until one of two things happen. A) If the collector current is increasing, eventually the transistor will run out of gain or B) if the collector current is decreasing, eventually the current will get to zero. At either end point, the collector current stops changing, so the reinforcement feedback stops, and the transistor switches to the other mode. This cycle now continues indefinitely.
Once started, the timing of these reversals is dominated by the resonance of the secondary with its self capacitance.
As @Hearth points out in comments, it's basically a Joule thief, or blocking oscillator circuit.
A combination of low input power and the 2N2222 being fairly tough allows this to keep working without blowing it up from overvoltage on the collector or base. More input voltage or a more fragile transistor would not work, at least not beyond the first few cycles.
I like circuits that are as simple as possible. If I'd started to design this, I'd probably ground the secondary with a pair of anti-parallel diodes, so that the discharge current is kept out of the transistor base, and then have to connect the feedback to the base. However, the capacitance of these diodes would change the phase shift and gain, and it may not start, and would use more components ... sigh! Perhaps it's worth the risk of killing a 2N2222 for the simplicity. Maybe just one little signal diode between base and emitter as shown to prevent VBE reverse bias. I'm sure that would not stop oscillation.
Peter Mortensen
  • 1,676
Neil_UK
  • 158,152
  • 173
  • 387
  • so its real, could you explain it a bit simpler please – Gabriel ashmore Jul 27 '21 at 04:01
    It reminds me of a joule thief. – Hearth Jul 27 '21 at 04:32
    Coincidentally looks like mine and it oscillates in either polarity probably weak magnetic coupling – Tony Stewart EE75 Jul 27 '21 at 05:03
  • @hearth yeah the schematic is almost the same as a 2 coil plus transistor joule thief. – Passerby Jul 27 '21 at 10:49
  • @Gabriel it uses a trick of a transformer coil to create an AC signal from a DC voltage source. By turning the DC on and Off rapidly, it becomes AC, and thus the transformer keeps doing its job. – Passerby Jul 27 '21 at 10:52
    Good simulators start with a residual voltage that is a tiny %age of the supply voltage on caps , so that the step voltage has the similar bandwidth of “white noise” or the same occurs with a step current from bias. So noise is less important an assumed requirement for oscillation, self start. Same applies to XO’s. – Tony Stewart EE75 Jul 27 '21 at 13:24
    A 2222 is a big fat gold-doped transistor that can tolerate a lot of base-emitter breakdown current. It makes a nice 7V zener. So the extra diode probably isn't needed. – John Doty Jul 27 '21 at 14:44
  • @JohnDoty There's got to be some reason 2222's survive. If it happens, it must be true. – Neil_UK Jul 27 '21 at 15:29
    If it hasn't already been said, I believe this circuit is also known as the "slayer exciter" – MC ΔT Jul 27 '21 at 15:51
  • This schematic is wrong. The end of the rightside coil, labelled "high voltage output", is NOT connected to the 9V battery's negative terminal through stray self-capacitance. It is connected to the ground through stray self-capacitance. The battery's negative terminal and the ground DON'T have the same potential, despite this answer suggesting otherwise. – Chad Branzdon Jun 28 '23 at 20:46
36
So its real. Could you explain it a bit simpler please?
Figure 1. Schematic drawn by Neil_UK.
  • When SW1 is closed current flows through R1 into the base of Q1. This turns Q1 on.
  • Current can now flow through XFMR1 primary through Q1's collector and emitter.
  • The current in the primary induces a voltage in the secondary. As drawn the dots indicate that the secondary voltages on the top of the coils will be positive.
  • The output voltage is fed back to the base turning the transistor on even more.
  • Eventually the current through the primary maxes out and can increase no more. Since transformers only transform when the primary voltage is changing and don't pass DC through the output voltage starts to collapse. This reduces the base current and Q1 starts to turn off.
  • The decreasing primary current causes the secondary voltage to go negative and this turns off Q1 even more until it is turned fully off.
  • The cycle then starts again.
Transistor
  • 168,990
  • 186
  • 385
A similar type of circuit is used in gasoline engines so that the 12V alternator can produce a high voltage spark to ignite the fuel/oil mixture. See https://en.wikipedia.org/wiki/Ignition_coil for more information.
A transformer does not need alternating current (positive-zero-negative-zero repeated indefinitely) but only requires that the voltage change with time. If you run DC power through the primary coil, it will store energy in the transformer, but no power will come from the secondary. If you suddenly cut the power to the primary, you have a very high rate of change of voltage (difference of voltage divided by unit of time) in the primary, resulting in a high voltage spike at the secondary. If you want more details, the Wikipedia article appears to be a good source.
Bradley Ross
  • 111
  • The alternator charges the battery and supplies 12 volts DC nominal to operate the vehicle. People have gotten several hundreds of volts from a car alternator but it is designed to output something in the 13 - 18 Volt range, not kV. The engine will start without a battery look at the drawing in your reference. There is a "transformer" normally called an ignition coil. When DC is supplied to the primary it stores a charge as a magnet flux, When the supply is removed the polarity reverses and the primary discharges causing energy to transfer to the secondary creating a multi kV pulse. – Gil Jul 30 '21 at 02:53
    I may have been unclear in my statement. I understand that the alternator only produces 12 volts and I indicated that it was a twelve volt supply. t – Bradley Ross Jul 31 '21 at 21:52
