I want to buy a water pump that has capacity DC 3.5V-9V 3W
which by my 5V USB charger makes 0.6A. My charger has output 5W 1A. Is it safe to exceed the 0.6A value by 0.4A?
Asked
Active
Viewed 91 times
JRE
- 67,678
- 8
- 104
- 179
Marcel Kopera
- 105
- 5
1The pump will only draw the amount of current it needs, the power supply does not force more current trough the load then it requires. A pump might draw a current spike at start-up tough. β Unimportant Jul 26 '21 at 11:55
Itβs never wise to exceed rated current with surges without storage capacity depending inrush current limits.
The pump power may rise >500% on startup and drop to 5/9 th of 3W max at 5V depending on load or lower. It is unknown how your load will react unless you test it with a flyback protection diode to opposite power rail.
Measuring pump DCR will tell you the start resistance and surge current.
- 3
- 54
- 182
thanks for the answer! So if I understand it good, it will takes only the current it needs, but it can instantly go high on a start so it could broke? β Marcel Kopera Jul 26 '21 at 12:00
