I have a nice bunch of TI LDC0851 inductive proximity switches and would like to use them for some anti-tamper experimentation, but their connection is 3x3mm WSON-8, which as far as eBay, Digi-Key, Mouser, TI, specialist obsolete product firms and so on have shown to no longer exist outside of somehow finding out some devices they were used in and then buying those devices to harvest the connector. I'm very much game to teardown some stuff to get the proper connectors, but I'm not sure how I would search for and find candidate devices with this specific connector.
I've contacted some firms about fabricating some new sockets from the datasheets and schematics, but cost and time are both absurd.
My idea is since I can have things 3D printed in conductive metals and the contacts on the chips begin at the side then go under, but at a narrowing slant, if I 3D printed eight contacts to fit under the chip a bit and a little up the side for a good contact and then attach surface mount tabs to each, soldering the 3D contacts on each side, is there anything that I'm missing that would cause the chip to not function properly? Interference, likelihood of excess EM radiation that would interfere with the chip reading the EM locations accurately, etc? Basically something beyond my knowledge that would be a reason to keep looking a solution?
Datasheet for LDC0851
UPDATED per Advice from PDF to screenshots and from whatever random file host I was using to Imgur:
Datasheet for the WSON-8 in 3x3 https://i.stack.imgur.com/3QqPc.jpg
Edit: Am informed this might be more easily done by other methods. More detail or where I might read more about this or, ideally, both would be appreciated if that's possible.
Edit Edit: Datasheet for socket changed to screenshots instead of PDF and Imgur rather than whatever random file host I had tried before.
