I'm attempting to interface a MEMS Microphone with an ESP32 through a CS8406.
I am aware that the ESP32 has a well-documented I2S hardware interface however for my project I cannot use it. (It's going to connect to a smartwatch I developed in which only I2C and UART are broken out, also the I2S pins are being used to write data to a display from the 70s..... it ate a lot of other pins as well, but very worth it!)
The protocol I'm using to transport the Audio data is I2C.
I have had a hard time finding anything other than the datasheet on this chip and I want to know if anyone has ever used it with its built-in I2C protocol.
I've attempted to make the connections according to the datasheet in Cirrus Logic CS8406
Here are my questions:
Is this a reasonable workaround or are there other methods?
Has anyone used this chip, and if so could you offer any advice?
Thanks!
