I'm trying to use this charger to charge a USB-C device (a MacBook).
The charger is specified for 12W (5V, 2.4A), and has Type-A, non-superspeed connectors. The MacBook states up to 20V, 1.5A or up to 20.3V, 3A.
When connected, the MacBook recognizes the power source, but states that it isn't charging. In reality, it charges at a rate consistent with a 5V, 1A source.
I understand that most 5V, >1A solutions were proprietary solutions, but is there any way to build (or ideally, buy) a cable that'd allow to charge at a faster rate?
Note: I've seen USB Power Delivery over Type-A connector and while it might lead to the answer, I haven't found it yet.
2021-07-13 edit:
I just tested the same MacBook & cable with an old Apple 10W USB-A charger (A1357). The MacBook sees it as an 8W source, and an USB current monitor sees 1.4A.
So the issue is not the cable, or at least not only the cable.
