For a periodic signal, we use Hertz, or the number of cycles per second, to quantify how fast its values are changing.
However, how can we quantify how fast the phase of a periodic signal is changing? Given that phase of a periodic signal is expressed in degree, can we use degree per second as a measurement of how fast the phase is changing?
Thanks.
Edit: Here are the illustrations of fast and slow changing phase.
Source: RF Microelectronics (Razavi) Fig. 9.15
Underdog
  • 367
  • In what sense is the phase angle changing? – Chu Jul 09 '21 at 00:22
  • As mentioned in the answer, for \$\sin(\theta) = \sin(\omega t)\$, \$\omega\$ *is* the speed with which the phase \$\theta\$ is changing. – AJN Jul 09 '21 at 00:52
  • @Chu Please refer to the edit as illustration of phase change. – Underdog Jul 09 '21 at 01:26
  • @AJN So you mean frequency is a measurement of phase change because the derivative of phase is frequency? – Underdog Jul 09 '21 at 01:28
    Yes. More details in the existing posted answer. – AJN Jul 09 '21 at 01:46
  • Phase angle doesn’t mean anything unless you reference it to something. What would you like to reference it to? – relayman357 Jul 09 '21 at 02:06
  • If you want to measure the phase or rate of change of phase of a square wave, the best you can do is estimate the phase (and rate of change) based on past history, and you can update it every time you see an edge. UNLESS you have access to additional information or signals. – user57037 Jul 09 '21 at 03:18
Generally, harmonic signals have a phase: the derivative of phase over time is the frequency of such a signal, I.e. a sine or cosine.
Now, not all periodic signals are harmonic signals. But we can decompose any periodic signal into a sum of harmonic signals (that's the Fourier series of the periodic signal).
It's easy to see that every harmonic component of that sum can have its own phase. There isn't such a thing as "the phase" for a non-harmonic signal.
However, it can be useful to think in terms of the phase of the fundamental frequency, I.e. the harmonic component of the same frequency as your periodic signal, and call that the phase of the non-harmonic periodic signal. However, that fundamental can, when the periodic signal is composed of two periodic signals whose periods are rationally related but not multiples of each other, be of zero amplitude and then you can't really define the phase of it.
So: long story short: strictly speaking, only harmonic signals have phase. Some periodic non-harmonic signals can be assigned a property analog to that concept, but not all of them.
mmmm
  • 1,759
  • Then suppose there is a harmonic periodic signal, how can we quantify the speed that its phase change? – Underdog Jul 09 '21 at 02:57
  • I answered that: find the Fourier series, find the frequency of the fundamental frequency component. – mmmm Jul 09 '21 at 03:08
\$d \phi/dt \$ can be measured in any units and extrapolated to cycles per second or 1 cycle/__us or Hz or as a % deviation from the initial frequency. Your choice.
80% of the phase change or 10 to 90% of the full scale also converts to T=0.35/f-3dB
