I have an x-ray closed transformer and I only can access to the primary terminals. I want to measure the inductance of the primary and to know how this loaded secondary influences it.
Asked
Active
Viewed 267 times
1The primary magnetization inductance is unaffected by the secondary loading. – Andy aka Jul 05 '21 at 15:06
So, if I try to measure the primary inductance with a resonance circuit, will it be the same as if I have a single coil? – Gabriel Quiroga Jul 05 '21 at 15:11
1No, the projected impedance from the secondary circuits will have an effect. I mentioned the above because I wasn't sure if that is what you meant but clearly you are interested in the primary referred secondary impedance. – Andy aka Jul 05 '21 at 15:18
Turns ratio squared inversely defines the secondary inductance and load impedance is transferred the same way when mutual coupling is assumed to be high.
So If Lp = 1 H and n = 10:1 Ls = 1/10^2= 0.01 H.
With load switched off you can measure Lp with an RLC meter and compare with V, I scope readings.
With load switched on , you may measure the power factor and inrush current as well as the crest factor on peak current to Average. But it ought to have active power factor correction if it is relatively new.
The easiest method is to use a current transformer or a neutral ground resistor for 50mV drop with coax and compare the ratios of Vin/In.
- 3
- 54
- 182
