I am bit confused about what exactly systematic offset is. I understood that generally offset could be due to two reasons:
  1. Random offset which could be due to mismatch in size of transistors or any other component. This will be like noise with mean zero.
  2. Systematic?
It would be great if you can provide an example with a differential pair or any such circuit so I strengthen my understanding.
Peter Mortensen
  • 1,676
Hari Krishna
  • 659
    Not an example of a systematic offset so much as systematic error, but in a differential pair, using a resistor (or even an active current source) in place of an ideal current source, since it only approximates an ideal current source, it is going to deviate from the ideal behaviour and introduce errors. It doesn't matter how perfect your components are matched or what the tolerances are, it's inherent limitation due to the fundamental implementation. That said, I am not sure if comparing to ideal behaviour is fair, but is an error when compared to the desired behaviour. – DKNguyen Jul 03 '21 at 19:08
  • This is the same as systematic and random error in a measurement system. A systematic offset (or error) is always present and mathematically well defined. Systematic offsets can be compensated for or eliminated or calibrated out. Random offsets (or errors) cannot be removed using calibration because they are unpredictable. Note that averaging can reduce the impact of random offsets (or errors). But averaging cannot reduce the impact of systematic offsets (or errors). – user57037 Jul 04 '21 at 18:16
    Surely you mean **systemic**, not "systematic"? – Jeremy Boden Jul 04 '21 at 19:28
  • @Jeremy Boden - OP probably is not differentiating between the two. Maybe if you would provide a formal definition of the two, it would help clarify the question. Sounds to me more like a " how many angels can dance on the tip of a pin" question. – SteveSh Jul 04 '21 at 23:45
  • Systematic offset of what? Amplifier gain? Output voltage? Frequency of an [VCO](https://en.wikipedia.org/wiki/Voltage-controlled_oscillator)? Oscillator amplitude? Measurements? Something else? – Peter Mortensen Jul 05 '21 at 05:16
    For a measured value `Vm` of a physical value `V`, a systematic offset is a constant `C`, ie : `Vm = V + C` - not proportional to the measured value. It is caused by the measuring system (ie: *system*atic) and not the measured signal. A ruler with an extra mm of material behind the first `0` mark will always measure 1mm under the true value, for example. – J... Jul 05 '21 at 13:48
Here is an example circuit with a systematic offset:
The bias current of a bipolar op-amp such as the venerable LM741 is not randomly distributed around 0nA, but rather always flows into the inputs (when balanced and under non-pathological conditions) and is typically 80nA. Schematic from datasheet:
If 80mV typical (500mV maximum) offset at the output is unacceptable you can add a 500K resistor in the path of the non-inverting input and the circuit will no longer have a systematic offset. Since the bias currents don't match perfectly and the resistors have tolerances there will still likely be an offset, just not a systematic one.
Spehro Pefhany
  • 376,485
  • 842
I had to look this up so take what I say with a grain of salt.
Just from the phrase alone, "systematic" means built into the system (or setup), not random.
Looking around for clarification, it means that even if the components are perfectly matched with perfect tolerance the offset would still be there due to fundamental non-idealities.
I couldn't think of such a situation, so I looked up some more. Apparently one of the most common causes of systematic offset (and systematic errors in general) is improper use or damage of measuring instruments. Which makes sense since it's an error inherent to the way you set up your system irrespective of tolerances or matching.
Random vs Systematic Error
Peter Mortensen
  • 1,676
DKNguyen
  • 54,733
  • 67
  • 153
    It sounds like you want an example of systematic offset for a particular system which I am probably not qualified to give. In any case, if that's what you want you should edit the system you are wanting an example for into your post. – DKNguyen Jul 03 '21 at 19:04
Here's an example.
Say you have a bunch of RF amplifiers connected in parallel so as to give you a higher output. Forget for the moment about how this combining is done.
All real-world amplifiers exhibit some variability between parts. They may have slightly different gains, or slightly different noise figures, or slightly different gains as a function of frequency. Their characteristics also may vary with temperature or power supply voltage.
Those first two factors might be considered random, as their affects on the overall system are not correlated. If the gain of one part is slightly above the average, it's probably compensated for by another part who's gain is slightly below the average (assuming the amplifiers gain have some sort of gaussian distribution about a mean).
The second two effects - temperature and power supply sensitivity, would be considered systematic as they affect all parts the same. For example, many RF amplifiers have a negative gain coefficient with respect to temperature. That is, as the temperature increases, the gain goes down. This being the case, if the temperature of the system increases, the overall gain decreases. This decrease in gain wrt temperature would be considered a systematic error.
SteveSh
  • 9,672
Systematic offsets of Ron and Vt
P-channel FETs have slightly higher Rds,On than n-channel for the same size, so in order to equalize them in totem pole CMOS logic to a standard value for that logic family, the p-channel must be made larger to match the n-channel. The output impedance can be measured or specified by Vol/I and (VDD - Voh)/I.
But they also have slightly different VGS(th) thresholds, so at room temperature the input threshold may be balanced closer to VDD/2 by design, but over the full temperature range the characteristic spans a broader range of offset by some +/- %.
Peter Mortensen
  • 1,676
A systematic offset would be like the DAC in the feedback path of a successive-approximation ADC, or some sort of auto-trim.
A systemic offset OTOH is there by design, like biasing a microphone amplifier to 1/2 VCC so that a single-ended power supply can be used.
Peter Mortensen
  • 1,676
