To minimize the costs for wiring an electronic enclosure, often designers put connectors at the edge of the PCB, that fit in slots made on the enclosure walls. The most common example is a mini PC:
To have an idea, in my application I need IP64 connectors with the following specifications:
- 2 pins: 24V 10A
- 4 pins: 2x 24V 10A + 2x signals
- 8 pins: signals
I went through the most common manufacturer catalogs but I didn't find a connector family that could fit my needs. Usually, most IP64 connectors are not available for PCB mounting because they are intended to be mounted on a front panel and then wired to the PCB.
Is there a solution for this request? Or I just need to stick with panel connectors and internal wirings?
