I noticed Everlight EAPLRAA4 receivers go into oscillation if there is no incoming light signal. Frequency depends, varies with the part, either 8..9MHz or hops to 32MHz. The supply is as clean as it can be - SMT 0.1u caps right on the pins of the receiver, ferrite bead on power, one more 0.1u cap after the bead. 22p is on the output as per the datasheet. Happens in a test breadboard setup and in production built audio switcher. When the incoming signal is present all works as expected. After the light is off, the oscillation builds up in less than a minute.
Has anyone seen this oscillation? Is this normal, perhaps specific to everlight?
