Please refer to this opamp design. Suppose all MOSFETs are to be fabricated on chip. The bias current is to be supplied externally.
How can this bias current be supplied externally? For example, can I use an LDO regulator? Or use an external voltage with an external resistor to generate a current as illustrated below.
However, the value of the resistor may not be accurate. So how can I ensure the accuracy of the external bias current?
Thanks.
Underdog
  • 367
  • If you need an accurate resistor, pick an accurate resistor. Or at least, select a resistor of your required value from a batch of stable resistors. Nothing says you have to rely on the label. Or use a pot. – DKNguyen Jun 19 '21 at 02:44
If I'm looking to use an external bias current as a reference for an IC (that I made), I would probably use the following solutions:
  1. A Source Measure Unit (SMU) - a piece of test equipment that frequently has a current sink/source mode, allowing for precise adjustment of current values. I've used something like a Keithley 2602 as a current source, giving me accurate and infinitely variable current values for IC bring-up without the fuss of building a "proper" stand-alone source. Great for trying things out, but not when you need something a bit more permanent.
  2. A fixed current reference IC. Something like TI's REF200 would be easy and (relatively) inexpensive to get a precise current source for some discrete current values. The LM334 is a variable current source, and I've also used this when I wanted to adjust the current value with a potentiometer.
  3. Just use a resistor/poteniometer to VDD. A potentiometer would allow you to adjust the current, while a fixed resistor might also be fine if your tolerance on the current is wide enough. The disadvantage of a resistor versus a current source is that if your IC changes temperature or if you try a different die, the current will vary.
If you try any of the adjustable (with a potentiometer) methods, add a fixed resistor in series as a shunt resistor so that you can measure the current (as voltage across a fixed resistor) without breaking the circuit to put an ammeter in series.
The real solution for this application is to either make a suitable current source in your block, or make a bandgap reference to act as an on-chip supply.
Resistor accuracy is a red herring - your NFET will vary much more than a cheap 1% off-chip resistor that you can easily get. If you doubt me, you can get an excessively precise resistor for much less than the cost of your IC fab run.
W5VO
  • 18,303
  • 63
  • 94
