I have a variable voltage called Vreg
(Voltage regulated) which is output of switching regulator (buck converter) and is less than 12v.
Also there is ANALOG Signal with voltage between 0 < V < Vreg < 12v
. (Vreg is less than 12v
). I need to scale my ANALOG signal from 0 < V < Vreg
span to 0 < V < 5v
span so that I can read it directly with Arduino. Also need it be economic with few parts or easily available parts like very common op-amps etc. Signal frequency is less than 50 KHz
Further Clarification:
The problem is that I have a DC FAN with an integrated RPM sensor. It have three exposed pins.
- GND
- VCC
- RPM Signal (Tach OUT)
Module Contains a DC motor, and sensor output is analog. Internal schematic of module is like this:
I need to control the rpm of motor, but the module do not have such capability so i need to play with input voltage VCC
to module. I've checked and it did work to control RPM. It can go down to near 0v
, but the problem is with Tach pin's signal which have no sufficient voltage if module input voltage is near 0v
. How i can overcome this?
I need an Intermediate circuit for this, and cannot use extra pin of UC like some answers below.
Thanks.
