- I found this VGA from texas instruments. On page 34 you can see a AGC (automatic gain control) loop, does this set the output voltage (Vout) to the Vref voltage?
- The VCA821 needs a bipolar supply voltage, I wanted to use this switched capacitor inverter to generate the negative supply voltage of -5V. My question is will the switched capacitor inverter be able to deliver enough current for a stable negative voltage on the VCA821s negative supply pin?
