14
Is a function generator necessary for every day lab use, or is it special purpose equipment? That is, does it have similar utility to an oscilloscope, or multimeter - would you use it regularly enough to justify it's cost?
Thomas O
  • 31,546
  • 57
  • How about getting the function generator, the oscilloscope and the logic analyzer for $35 ? [Xprotolab](http://www.gabotronics.com/development-boards/xmega-xprotolab.htm "Xprotolab") –  Dec 03 '10 at 19:13
9 Answers9
25
If you're working with digital systems and square waves/pulse trains only, then it's probably not necessary. However, for analog amplifier design (ex. audio), it's an imperative.
If you haven't been stymied on a project because you lacked this tool, you probably don't need it. Spend your money on an oscilloscope and logic analyzer instead. Conversely, if you can't imagine why you would need a logic analyzer, you should spend your money on a function generator.
Kevin Vermeer
  • 19,989
  • 57
  • 102
    yep, critical for analog design. I also highly recommend a scope/function generator that is controllable via USB or GPIB. Throwing together a quick matlab script that running a fully automated frequency response test on a live circuits is a massive time saver. – Mark Oct 26 '10 at 17:12
  • Seconded on both. – Kortuk Oct 26 '10 at 19:43
  • @Mark Did you write your own driver for matlab to talk to your USB devices, or was it provided by mfg.? Sounds like a great idea. – tyblu Dec 03 '10 at 20:19
  • @tyblu Every device supports its own set of commands but the low level communication functions are generally provided by the manufacturer, or you can use one of several free GPIB libraries that are out there, I like pyVISA. – Mark Dec 05 '10 at 01:36
In the audio frequency range you can use your soundcard. Use google to find the software.
russ_hensel
  • 2,904
Depends on what waveforms would be useful in everyday work. I like to play with waveshaping and signal processing, so a good versatile function generator is one of my favorite instruments. It's likely to be useful for almost anyone into electronics who's gone beyond building crystal radios and blinking LEDs. A more important question is: which waveforms will you need, and at what quality?
Sines are good for testing linear filters, taking measurements at specific frequencies. For accuracy, the sines have to be low distortion. Less expensive generators have poor sine waves (look at the THD).
Triangles and squares are good for testing amplifiers - our eyes aren't sensitive to small deviations from a sine, but are very good at seeing problems with straight lines and square corners.
Ramp waves are good to sweep oscillators over a frequency range, which is also good for testing linear filters, and also circuits like mixers, modulators/demodulators, and audio testing.
If you're into experimental physics, pulses that you control in fine detail can be useful in controlling equipment, data acquistion, strobing to observe fast repetitive phenomena.
In most cases, for serious accurate work there are specialized instruments for the job, but even with a budget for such things, a function generator is useful for quick and dirty experiments of all kinds.
DarenW
  • 4,060
  • Feeding a triangle wave into an amplifier whose amplitude and phase response are uniform at all frequencies, and whose output is non-distorted will yield an output which is clearly recognizable as "good"; it would be unlikely for the effects of distortion and non-uniform frequency response to cancel. On the other hand, if the phase or frequency response isn't uniform, the triangle wave will end up somewhat curvy, and it may be difficult to discern to what extent that is a result of distortion versus frequency response. A type of wave that may be useful for that purpose, but which... – supercat Jun 24 '13 at 19:18
  • ...I've not often seen offered in function generators, would be a sum of two triangle waves of different frequencies (e.g. selectable 16:1 or 64:1 difference), but locked phase. The higher-frequency wave should have an amplitude which is relatively independent of its position on the lower-frequency wave; non-uniform frequency response wouldn't change that, but distortion would. – supercat Jun 24 '13 at 19:23
I found a fairly cheap one for $153: http://www.bellnw.com/products/0762/
It's pretty much no-name but it will certainly be quicker for me to use as the PWM input to a breadboarded switch-mode power supply than rigging up something with an Arduino and op-amps. Plus, only $153. That's an expensive dinner for four, or a couple of outfits. If you'd buy a $1k plus scope, buy this, no question.
EDIT: It may be worth it to get the SFG-1013. It has a voltage display.
AngryEE
  • 8,669
This all depends on what work you are doing. Some people don't even need a scope or a dmm.
More generally, some people will say its not worth getting a computer (even some EE's), yet I am sure most of us would argue it is worth it.
So what work do you do that you wish you had a function generator? If you can't think of anything then it's not worth it.
Kellenjb
  • 17,509
  • 51
  • 87
  • If Thomas need only doing some square waves, he doesn't need it (a 555 or a tiny MCU can do that for under 10USD). But for precision sine wave generation is a must. Scope (or at least a fairly good multimeter, with AD/DC voltmeter and frequencymeter) and computer (for datasheet reading at least) are a must too. – J.P.Wack Oct 26 '10 at 16:30
  • Yes, but this comes back to whatever he wants to do. With a 555 and some filters I can create a precision sine wave for under 10USD. – Kellenjb Oct 26 '10 at 16:45
  • well, that too, but for a wide range of freqs the changes in the filter can be very time consuming. – J.P.Wack Oct 26 '10 at 17:34
    All about how much money your own time is worth. – Kortuk Oct 26 '10 at 19:43
If you check ebay, you can quite a few between cheap and $50. Frankly, I'd do that and put your extra money into oscilloscope.
briefer
  • 66
A software DDS with a suitable MCU is a low-cost way to make a function generator. This design of mine will go up to 200 kHz or so.
Leon Heller
  • 38,774
  • 60
  • 96
As far as a good all-around tool, I've had pretty good luck with the National Instruments myDAQ (not an advertisement, we bought a couple to evaluate for our EE department). They can be had for 175 dollars with the educational discount, and it covers most of the basic needs. It is basically a function generator, an oscilloscope, and a multimeter all in one.
The analog output (function generator) operates at up to 200 kS/s, meaning that you can pretty accurately generate waveforms for the audio spectrum (I believe that the software allows up to 20kHz). Much higher, and you'll have to shell out more money. The feature that I like is the arbitrary waveform generator, which can be very useful depending on the circuits that you are building.
Basically, the need for most test equipment is determined by what sorts of projects that you are working on. If you are doing hobby-level projects, you may not need any sort of expensive hardware.
mjcarroll
  • 1,974
As a relative newbie into electronics at a later point in life, I concur with the myDAQ suggestion. You also get LabView with it that is very robust plus a ton of other benefits and features including MultiSim. This doesn't even scratch the surface.
TechShop (www.techshop.com) opened a location near me late last year (Austin/Round Rock location), and they have them available at the educational price and also have training classes. In addition to all of their other tools and machinery, there's also an electronics lab there with scopes, function generators, most of the usual bench equipment, a small re-flow oven and a little ShopBot for making PCB's, just to name a few.
    Perhaps this post would be better as a comment to the relevant answer, rather than as a separate answer: It does not really add significantly new information that other answers have not already covered. Also, the promotion of the specific vendor comes across somewhat as unsolicited advertising, just saying. – Anindo Ghosh Jun 24 '13 at 15:22
