I am developing an assembly application that includes a HD-44780 compatible 20x4 display over the I2C bus. After several attempts, I have finally managed to initialize the display in 4-bit mode and show a message, but after a few seconds the display seems to go crazy.
To eliminate the possibility of a bad initialization, I have tested the display with the Arduino example sketch I2C_Hello_World.ino, with the same result.
This 15 second video shows the behavior of the display
This is the sketch:
#include "Wire.h" // For I2C
#include "LCD.h" // For LCD
#include "LiquidCrystal_I2C.h" // Added library*
//Set the pins on the I2C chip used for LCD connections
//ADDR,EN,R/W,RS,D4,D5,D6,D7
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7,3,POSITIVE); // 0x27 is the default I2C bus address of the backpack-see article
void setup()
   // Set off LCD module
   lcd.begin (20,4); // 16 x 2 LCD module
   lcd.setBacklight(HIGH);
//   lcd.clear();
   lcd.setCursor(0,1);
   lcd.print("LEDMedia art digital");
   lcd.setCursor(0,2);
   lcd.print("Traverser v.0.0.1");
void loop()
Is this display damaged? Has anyone else come across this behavior? If the display is not damaged, is there a hardware or software reason to explain it?
Thanks for your help.
Laura
  • 131
  • maybe, since you are not turning the backlight on and off i suspect something goes wrong – arnisz May 24 '21 at 10:41
    Was this one time or it happens every time when you flash the code to the arduino? (+ Add a schematic) – Mitu Raj May 24 '21 at 10:59
SOLVED !
It was the NANO board that was damaged. The display works correctly connected to an original Arduino UNO board with the same sketch.
Laura
  • 131
