I want to use a PGA (programmable gain amplifier). I found the LMH6881 which I will be probably using.
On page 5 of the datasheet you can see that the analog input voltage range should be between 0V and VCC (which is 5V). On page 6 of the datasheet it is stated that the input common mode voltage is 2.5V (self-biased).
So why isn't it possible to apply a single-ended -2.5V signal to the analog input. If it is self-biased then it should still be in the range of 0V to 5V, right?
