A design has a number of simulation ports that should not be tied to FPGA pins.
A VHDL example is shown in the source below, where the sim_only_* ports are for simulation only, thus should not be mapped to FPGA pins.
entity mdl is
port(
-- FPGA pins
clk_i : in std_logic;
rst_i : in std_logic;
a_i : in std_logic;
z_o : out std_logic;
-- Simulation pins only
sim_only_in : in std_logic := '0';
sim_only_out : out std_logic);
end entity;
The sim_only_* pins can be safely left unused by Quartus, since the inputs have default value.
When running Quartus, the mapper tries to map the sim_only_* ports to unused FPGA pins, which is not desired.
How can I specify that Quartus should just ignore the sim_only_* ports on the VHDL design?
