In preparation for an exam in linear signals and system my instructed handed us a couple of conceptual questions that should prepare us. I ran into the following:
Which statements regarding the Laplace transformations are true?
  1. Multiplication of two signals in the time-domain corresponds to convoluting the signals in the Laplace-domain.
  2. A differential equation can not be Laplace transformed if the roots in its characteristic equation lie in the RHP.
  3. Opposite the Fourier transformation, the Laplace transformation of the system response includes both zero input response and zero state response.
  4. The Laplace transformation of a system's step response gives the systems transfer function \$H(s) \$.
My attempt at reasoning
1 is wrong. It's true that \$x_1(t) *x_2(t) = X_1(s)X_2(s) \$, but \$x_1(t)x_2(t) = \frac{1}{2\pi j}X_1(s) * X_2(s) \$, so it is not equivalent.
2 is wrong. If the poles lie in the RHP doesn't mean that a Laplace transformation \$H(s) \$ doesn't exist, but it means that the system is unstable, the frequency response doesn't exist and \$H(j\omega) \$ is meaningless.
4 is wrong. It is the Laplace transformation of the impulse response \$h(t) \$ that gives the system transfer function \$H(s) \$.
3 I believe is correct. I just think of transforming a capacitor with an initial voltage to the Laplace domain, which will result in an impedance \$Z_c=\frac{1}{sC} \$ in series with a voltage source \$\frac{V_c(0)}{s} \$. So both the zero input and zero state response is taken care of.
However, the only answers available for this question state that either all of the statements are wrong, or that at least two of the statements are correct, which doesn't agree with my reasoning. Can someone spot a flaw in my reasoning?
Carl
  • 3,646
    Hint: "corresponds to" doesn't necessarily mean "is exactly equivalent to with no need for a scaling adjustment". – The Photon May 14 '21 at 18:26
  • @ThePhoton hmm I guess you are right. If that is the case I suppose 1. and 3 are the correct options. – Carl May 14 '21 at 18:28
    Actually, \$H(j\omega)\$ has meaning for an unstable system, and can even be measured on a physical system if you first wrap that system with feedback that renders the overall system stable. – TimWescott May 14 '21 at 18:53
  • @TimWescott Are you sure about that? This quote (marked in yellow) from signal processing and linear systems by Lathi seems to state the opposite. https://i.stack.imgur.com/vwcTG.png – Carl May 14 '21 at 19:04
  • That's in a signal processing context, where everything is feedforward. But a physical system can have unstable parts, and you can use that unstable part's \$H(j\omega)\$ in a meaningful way to design a system that's stable overall. – TimWescott May 14 '21 at 19:25
  • @TimWescott Mathematically, to me that just doesn't make sense. Let's say we have a function \$f(t)=-e^{2t} \$ that in the Laplace domain has the pole at \$s=2 \$. The Laplace integral now becomes \$F(s) = \int_{-\infty}^{\infty}f(t) e^{-st} dt = \int_{-\infty}^{\infty}-e^{2t}e^{-(\sigma + j\omega)t} dt = \int_{-\infty}^{\infty} - e^{(2-\sigma-j\omega)t} dt \$. Now, \$H(j\omega) \$ is found by setting s = jw and then evaluating the integral, but as you can see, this will result in a growing exponential that will make the integral go towards infinity instead of converge. – Carl May 14 '21 at 19:49
    1: It works. Control engineers stabilize unstable systems all the time, and they often do it using Laplace-domain analysis. Examples abound. 2: If the math can't keep up, that's the math's fault. 3: if you can't believe that -- ask a separate question; said question is certainly answerable. – TimWescott May 14 '21 at 19:53
    For the purposes of your question -- if it's a signal processing course, just give the signal processing answer. Google "The Return of the Archons" for how things can go bad if you don't ostensibly follow authority, even if it's misguided. – TimWescott May 14 '21 at 19:55
  • @TimWescott Understood. – Carl May 14 '21 at 20:04
  • I'm also confused with that integral, and what Carl and Tim are looking at. For the ∫e(a−s)t , it has ROC from +a to +∞ , so you just can't, say, evaluate an FT (at a=0, the imaginary axis). But the LT 1/(s-a) coming from the indefinite integral exists, and its value is finite and analytic everywhere except at s=a (and the singularity has a residue, is mild mannered) so we can do countour integrals anywhere in the s plane, and of course unstable transfer functions exist physically and behave very well. Where's the disconnect? – Pete W May 15 '21 at 13:21
Both 1 and 3 are correct. Both 2 and 4 are wrong.
1 is correct. By duality principle, multiplication in time domain corresponds to convolution in the frequency domain and vice versa.
3 is correct as LT provides us the complete response zero input (transient) and zero state response (Steady State). By contrast, FT gives us only the steady state response.
cdeamaze
  • "duality principle" is for Fourier transforms. Laplace original and transform domain characterisation and convergence conditions are way too different to leave room for "duality". Due to the relationship with Fourier transforms, a few pieces of "duality" intuition may work out given specific convergence constraints, but any rigorous proof will require elements of convergence and analyticality that have no dual counterpart. – user107063 Jan 08 '23 at 04:57
