I can't solve this problem because the opamp's positive input has 2 sources.
How can I calculate my output and gain when 2 sources are connected at the positive input of the opamp?
SamGibson
  • 17,231
  • 58
    More sources: Superposition rule. – LvW May 14 '21 at 13:28
  • ok thanks your answers. I do it – studentman May 14 '21 at 13:31
  • studentman - what about the third signal source? Is it zero? Otherwise, you have to consider 3 inputs at the same time. – LvW May 14 '21 at 13:57
  • LvW excuse me! forgot this 3. source 10 v – studentman May 14 '21 at 13:59
  • With a gain of 150, what Vin- does it need to null the output from the Vin+ Reference voltage which is 1/3rd the way above 3 towards 5V. (3+2/3V) BTW, the gain won’t affect the offset null, so Vin- must = Vin+ – Tony Stewart EE75 May 14 '21 at 14:16
  • By nulling the output, I meant nulling the input to output feedback current from Vin-. This is how one uses a single supply with gain and some reference V on Vin+ as the common mode voltage for input (Vin =Vin-) =Vin+=Vout then gain amplifies around this offset on Vin+ Or visa versa. ? Make sense? – Tony Stewart EE75 May 14 '21 at 14:34
  • There is no useful output. The opamp will try to make an output of 550 V, but it can't do that. – AnalogKid May 14 '21 at 18:44
  • I’m voting to close this question because homework needs an attempt at a solution, edit your question and provide the solution – Voltage Spike May 14 '21 at 22:13
The Golden Rules of Opamps apply to non-inverting input: no current flows into the inputs of an opamp.
Now, calculating the voltage at the node between R3 and R4 should be very basic network theory!
Marcus Müller
  • 88,280
  • 131
  • 237
Perhaps the simplest way is to use superposition (which assumes the op-amp is linear).
By inspection you can see that gain is +151 from the non-inverting input, and -150 from the unmarked voltage source on the left, assuming an op-amp with very high gain.
You can even include input bias current and offset voltage contributions using superposition if you want, but usually problems of this sort ignore input bias and offset currents and input offset voltage.
Spehro Pefhany
  • 376,485
  • 842
Perhaps a graphical solution will help you calculate the IN+ voltage.
Figure 1. (a) The equivalent circuit. (b) A voltage graph.
  • The current through R1 is going to run downhill from V1 to V2.
  • The total voltage drop across R1 + R2 = V1 - V2.
  • The relative voltage drop across R1 and R2 will be proportional to their ratios.
  • Now it should be clear from Figure 1b that V+ is two-thirds of the way between 5 V and 3 V.
The rest is a little bit of algebra.
Transistor
  • 168,990
  • 186
  • 385
-2
How to analyze circuits
Unknown circuits should be analyzed not blindly as an eclectic mixture of elements but by breaking them into well-known circuit building sub-blocks and concepts.
OP's circuit
Edit: Guided by this "golden didactic rule", we should not consider the OP's circuit as consisting of four resistors and an op-amp but of two sub-circuits - a passive resistor summer (R3 and R4) and an op-amp non-inverting amplifier (R1, R2 and the op-amp).
Passive summer
It is an extremely simple circuit of only two resistors with "magic" properties. It sums the input voltages of single-ended (grounded) sources by pre-scaling them with weighting factors (<1); its output is also single-ended. This circuit is an excellent example of the superposition principle. It can be seen in many other circuit solutions the most famous of which is the inverting amplifier. I have collected related links in my answer to a similar question. The most interesting of them is a Wikibooks story created by my students in 2008.
Non-inverting amplifier
Looking from the side of the summer output, we see a "reversed voltage divider" consisting of an ordinary voltage divider with a gain of R1/(R1+ R2) and a "reversing" op-amp. The op-amp drives the voltage divider input so that to make its output voltage at the inverting input equal to the input voltage at the non-inverting input. As a result, the op-amp output voltage is (R1 + R2)/R1. See more about this explanation in the Wikibooks story created by my students in 2008 and in my RG question.
Inverting amplifier
Looking from the side of the third voltage source (on the left), we can see something very interesting - the two resistors R1 and R2 form the same passive resistor summer as the network of R3 and R4. Here the humble 2-resistor network sums the third input voltage and the op-amp output voltage... and since the latter has an opposite polarity, this is actually a subtractor.
So we can consider R1, R2 and the op-amp not as a combination of two resistors and op-amp but as consisting of a resistor subtractor (R1 and R2) and op-amp. The subtractor is needed for the purposes of the negative feedback (comparison and attenuation).
Two summers
Very interesting... It turns out that we can consider the whole OP's circuit as consisting of two resistor summers and an op-amp? And what does the op-amp do here? It keeps up the output voltage of R1-R2 summer equal to the output voltage of R3-R4 summer.
Circuit fantasist
  • 13,593
    Quote: "The total gain of the whole circuit is a product of their partial gains." This rule applies when two gain stages are connected in series......does this apply in the present case? I dont think so.... – LvW May 14 '21 at 17:28
  • @LvW, I mean the resistor summer and the non-inverting amplifier are connected "in series" (cascaded)... Ohhh... sorry, I have not seen the third voltage source on the left... maybe you mean it... – Circuit fantasist May 14 '21 at 17:30
  • No - in any case, if there 2 or 3 input sources. ....In all cases, the gain values are not multplied. We cannot combine the gain values (because of different input signals). We only can add the output signals (superposition). – LvW May 14 '21 at 17:42
