I pulled some LM13700 OTAs from an old board and tested them. All voltages, currents, and resistances were measured. I had the expected (approximate) voltage gain using the equation \$ A=(R_2/(R_1+R_2 ))*g_m*R_L \$ where gm equals \$ 19.2*Iabc \$.
The problem begins when I use the linearizing diode on pins 2 or 15. The gain goes down substantially, the higher the current on these pins, the lower the output. I have used Marston’s equation from the old Nuts and Volts article, \$ I_{out}=2*I_S*(I_{bias}/I_D ) \$ but the result are way off.
Does anyone know of a better way to calculate gain in an LM13700 when the linearizing diodes are used?
UPDATE - I got a couple of new LM13700s and got the same results.
apoch
  • If they are old, you may have to consider that they are damaged. – a concerned citizen May 12 '21 at 21:26
  • It might pay off to conduct some tests, yourself, plot some graphs, then see if you can modify or make your own formula. Looking at its [internal schematic](https://electronics.stackexchange.com/q/156988/95619), those diodes provide a way to over-bias the inputs. So if you increase the current, the differential input might be driven into saturation, therefore the gain decreases. – a concerned citizen May 13 '21 at 22:22
0 Answers0
