I am working on a project where I need to find the location of a needle that has the IR detector at the tip of the needle.
These needles are medical suturing needles that would help us to detect the position of the suturing needle while suturing. Normally while suturing, if the doctor is not well trained, a bad suture can cause trauma to surrounding tissues. Currently, it's just an idea and we are working on a prototype. We will also be working with a lot more sensors to get the data while suturing but that has more to do with the software part and not the electrical part.
I need to actuate the frequency of the IR detector-emitter (LEDs) in such a way that I can gauge the location of the needle when the IR detector detects at respective frequency bands (typically 20Hz, 25Hz, 30Hz, 35Hz, 40Hz.)
So something like if the needle is in position A, then the IR detector will detect it as we will actuate it at 20Hz for position A, 25Hz for position B, 30Hz for position C, and so on.
This is an idea that I had but I am struggling to implement it and get its logic right with the circuit. Could someone suggest to me an electrical design or forward me some examples of electrical circuits that I can view and implement the above idea?
Thank You! All the help is really appreciated!
SamGibson
  • 17,231
  • 58
DevanshS
  • Comments are not for extended discussion; this conversation has been [moved to chat](https://chat.stackexchange.com/rooms/124189/discussion-on-question-by-devanshs-detecting-a-location-of-the-needle-inside-a-c). – SamGibson May 12 '21 at 19:33
    As this moving of comments to chat can only be done once, any further comments posted here which try to clarify and understand the question, might be deleted without notice. That's because the process would then be split into two places (comments and chat) and we don't want that. So... **Keep it in chat, please!** When someone has got enough information from the chat to post a valid answer, then please do that. Any factual updates to the question which are decided during the chat, should be made via an [Edit] to the question. Thanks! – SamGibson May 12 '21 at 19:37
An idea is to use short pulses of increasing length for the different emitters, then using an MCU, calculate the height ratio between the peak levels.
This method should be quite tolerant to the distance of the emitters and mostly conjugates to the position of the needle between the different LEDs.
It should also be fairly easy to accomplish with a bit of analog circuitry and coding.
Synced LED Pulse:
Signal on the receiver & detection of the ratio (sorry not very well aligned graph): enter image description here
From the distances %, you can evaluate how far you are from each LED, it could even, theoretically, do 3D positioning.
Another method could also be TOF (Time of Flight)
Damien
  • 7,827
