I am following this worksheet and I am struggling to understand the following piece of code:
# Stop when the Echo pin is no longer high - the end time
while GPIO.input(pinEcho) == 1:
StopTime = time.time()
# If the sensor is too close to an object, the Pi cannot
# see the echo quickly enough, so we have to detect that
# problem and say what has happened.
if StopTime - StartTime >= 0.04:
print("Hold on there! You're too close for me to see.")
StopTime = StartTime
break
I have implemented the worksheet's instructions and the code and when the sensor is very close to the object, I see the ...You're too close...
message on the console. However, the condition StopTime - StartTime >= 0.04
and the associated statement ...You're too close....
make no sense to me.
If StopTime - StartTime
is greater than a specific value, does it not mean it is taking longer than we want for the pulse to reach the Echo pin? Does that not in turn mean that the object is too far (rather than too close) for the sensor to detect it?
As far as I know, the echo pin is initially zero. When it gets the return pulse, the echo pin changes from 0 to 1. We record this instant as the start time. We then wait for the echo pin to change back to 0 from 1. This instant is recorded as the end time. This StopTime - StartTime
check is happening while the echo pin is 1 and we are waiting for this pin to become 0. So if the echo pin is 1, the echo pin has already sensed the return pulse, hasn't it?
