Is there any way to simulate (show on oscilloscope ) the sum of more than two periodic signals on PROTEUS?
Asked
Active
Viewed 244 times
Put as many different signal voltage sources as you need in series. Each one can produce an output voltage that is totally independent (or not) of the others. Putting them in series ensures that the overall output terminals is a voltage that is the sum of all the individual voltage sources. Connect to the scope input.
Or, if you can't put them in series, connect each signal to a voltage controlled voltage source and wire the output terminals of each VCVS in series to create the same effect.
- 28
- 351
- 777
Thank you @Andy aka. – user137684 May 09 '21 at 14:45
