I made a prototype circuit to detect the loss of individual 12V lithium batteries in a larger parallel bank due to BMS cutoff (12V continuous signal from an individual battery suddenly becomes open circuit). It's just a 10k/5k voltage divider on the Vin side, and a 10K pullup resistor on Vout.
I got the idea from this forum when someone answered my overall logic question by suggesting a mosfet inverter, but I found the 1K resistor they suggested on the input was too low to provide enough voltage to close the gate, so I had to increase it to 5K. I'm using IRF510N models, so maybe that was the difference although IRF530N appear similar.
But the circuit relies on the gate being held closed indefinitely so Vout remains at 0V. This could continue for months, or even years. Will the gate reliably open after all that time when Vin goes to 0V? It works fine now, but I can't find much about mosfets being held closed like this.
I'm not exceeding the max Vgs value, so there's no apparent stress being applied based on the datasheet's parameters. But even so, continuous operation like this is a problem with devices like side stable relays, even ones rated for continuous operation, which were my backup plan, so I wondered if mosfets have some similar issue. I hope not!
Thanks in advance.
