This is a bit of an open question but I am seeking advice on further research and also some search terms so I can find the best solution.
The project requires a 48V source from a battery pack which needs to be boosted to 600V-800VDC (allowing a smaller CSA cable to be used), this will then be stepped down again to a more useable voltage for a load with a 500W power requirement.
I would ideally like to use a dedicated management IC but cannot find anything that meets the voltage/power requirements, so looking for advice on what SMPS or power conversion topologies to investigate further.
