I'm trying to simulate two scenarios in LTspice. One is when things are ok. The second is when a short happens. As you can imagine I'm a beginner with LTspice. At first I was just putting a resistor at the output of my circuit to simulate my load. And when I wanted to simulate the short, I put the resitor at 1 mohm.
But I'd like to "automate" this. A short that happens after the sim has been running for some time.
I tried this. But I don't have a perfect zero when shorted.
But I've seen another solution:
When I do this I get the error : Can't find the definition model "SW".
EDIT: Thanks to Winny and his link I was able to correctly set up my short. You can also find more about switches in a post here
Neeko
  • 51
  • Hit F2, then look under the "Misc" folder and find "jumper." For a way to connect two different nodes, anyway. That may achieve what you want. Let me know, if not. – jonk Apr 29 '21 at 08:02
  • @jonk but the jumper doesn"t turn ON or OFF "alone"? – Neeko Apr 29 '21 at 08:05
    For your switch problem, you need to add a spice directive as outlined here: https://www.analog.com/en/technical-articles/ltspiceiv-voltage-controlled-switches.html# and name your switch to the same as in the spice directive. – winny Apr 29 '21 at 08:06
    @Neeko I was thinking you could just add it or remove it, running each time. Up to you. The other option is the voltage controlled switch you had trouble with. I was just trying to avoid writing up details on that. (I've written about it [here](https://electronics.stackexchange.com/a/372297/38098), for example.) – jonk Apr 29 '21 at 08:14
  • @winny Thanks for the link. It was detailing at the end how to do a proper short with that switch. – Neeko Apr 29 '21 at 08:31
  • @jonk Before posting I search for " switch" in the research bar but your post didn"t come up... – Neeko Apr 29 '21 at 08:33
  • @Neeko Well, hopefully the link helps. – jonk Apr 29 '21 at 08:34
0 Answers0
