I am trying to setup my own library folder without using the altium 365 or the vault feature. Is there a way I can install all the intlib/pcblibs+schlib all at once or make it part of a project template? Without needing to go through every folder and installing it manually every time
Asked
Active
Viewed 163 times
If you have alitum 20, then yes. Just create a design workspace (.dsnwrk) and then you should be able to import or create pcb project files (.prjpcb files). You can either add the libs into the project or through tools->preferences->data management->installed libraries
Voltage Spike
- 75,799
- 36
- 80
- 208
Well i am using 21, but when i add it through data management it is still one by one or if i use the search path it doesn't show any results. Do you maybe know how to fix that? – morpall Apr 28 '21 at 20:13
If you make it part of a project, you should be able to drag the files into the project window. – Voltage Spike Apr 28 '21 at 20:43
Works in all (~10 years anyway) versions of Altium. Not new for AD20+. – Chris Knudsen Apr 28 '21 at 20:52
And AD20 is pretty much AD21 in form and function anyway. I still run AD17 mostly, the UI is much easier to use and has better features – Voltage Spike Apr 28 '21 at 21:45
