Please help me solve this star delta problem:
Star Delta Transformation question
My attempt:
Attempt at solution
What to do next to solve this completely?
SamGibson
  • 17,231
  • 58
  • It looks like homework so you need to show some effort. You seem to know that you'll need to do a star-delta (or delta-star) transformation so where are you stuck? What do your course notes or your web research tell you? Please [edit] to show your work. – Transistor Apr 22 '21 at 19:52
    You've done the hard part. Can you see that you have 12.2 in parallel with 7.4? – Transistor Apr 22 '21 at 20:04
    I didn't check the exact numbers, but it looks like you already did the hard part. Maybe a short break will help? – jippie Apr 22 '21 at 20:05
  • Yes, I solved it Total Resistance=3.69 ohm – Shivam Jaiswal Apr 22 '21 at 20:07
  • Thanks for help. – Shivam Jaiswal Apr 22 '21 at 20:08
    Can you post your solution as an answer and then accept it so the system knows your question is solved. Otherwise it keeps popping up hoping for an answer. Thanks. – Transistor Apr 22 '21 at 21:46
