I am using the Falstad simulator.
I do not understand why am I getting a DC current through a capacitor in simulation.
This must be an error from the simulator. Please, let me know if I am sane, I don't get why there is current flowing.
JRE
  • 67,678
  • 179
JCSB
  • 277
  • wild guess: what's your time scale? Are you **sure** this is actually a constant current? (Hint: if I ask that way....) this really feels like you want to revisit how current through a capacitor depends on the time-dependent voltage. – Marcus Müller Apr 16 '21 at 17:36
    Try to put a small resistance (0.1R) in series with the capacitor. And restart the simulation. – G36 Apr 16 '21 at 18:13
  • I'm suprised this works at all - Falstad won't let you connect a direct-cap loop like that. You can post the sim by using "export as link" then pasting the long URL as a link reference. Then we can have a go and see what it's doing. – hacktastical Apr 16 '21 at 18:34
  • Nothing beats letting out the magic smoke for real. Because you rely on creating things from formulas, than guess the part and simulate it. – David Mikeska Apr 16 '21 at 19:18
Looks like you found a convergence corner case.
  • Cap directly connected to voltage source: Falstad detects the cap loop and says no.
  • Cap connected via ground: Falstad doesn't detect the loop, oscillates (what you're seeing.)
  • Cap connected via resistor to ground: Varies. Below 100 mohm, won't settle down. Above 100 mohm, converges.
Here's my sim (clicky here):
Point being, avoid direct capacitor (and inductor) loops to fixed sources. These always cause trouble with SPICE and its derivatives.
hacktastical
  • 49,832
  • 47
  • 138
  • Convergence is hard. Since it's been distilled into a simple test case, the OP may want to report this bug to Falstad so they get a chance to fix it. For the [CircuitLab circuit simulator](https://www.circuitlab.com/) we've been able to permanently fix many convergence issues from user bug reports over the years. Most recently 3 weeks ago thanks to an [EE.SE question](https://electronics.stackexchange.com/questions/552716). – compumike Apr 16 '21 at 19:33
