Is there any circuit that has a pole at an infinite frequency and zero at some finite frequency? A first-order RC Low pass filter has a finite pole and zero at infinity and it makes sense, I am just curious if another way around is possible in circuits?
Asked
Active
Viewed 224 times
2Theoretically -An ideal differentiator using op-amp but practically filter will be saturated after certain value of frequency and doesn't behave linearly . – user215805 Apr 08 '21 at 17:06
'zero at finite frequency' makes no sense, you mean 'a finite zero' – Chu Apr 09 '21 at 00:10
@user215805 Thank you! – sumita sahu Apr 09 '21 at 09:17
a pole at an infinite frequency ...
No.
Low pass will be \$ H(s) = \frac{1}{1+s}\$ and it has no zero. It is not the same as "zero at infinity" , which is not really a thing, and would be \$ G(s) = \frac{s-\infty}{1+s}\$ and for any \$s \in \mathbb{C}\$ it would be ill defined.
jDAQ
- 2,517
- 1
- 9
- 19
1This accepted answer says otherwise -https://electronics.stackexchange.com/questions/159939/what-does-it-mean-to-have-a-pole-or-zero-at-infinity – user215805 Apr 08 '21 at 16:48
@user215805 the difference start with this OP asking if there is a circuit that does that, which is no. Second, I agree with the linked answer about the behavior as s->infinity. But I disagree with the analysis saying s=infinity then we will have a zero/pole, because \$ \infty \not \in \mathbb{C} \$ – jDAQ Apr 08 '21 at 17:32
Isn't in some context frequency used for imaginary part of S and pole at infinite frequency mean gain (magnitude of frequency response ) tend infinite when frequency tends to infinite ? – user215805 Apr 08 '21 at 17:43
@user215805 Transfer functions are s-space and include both frequency as well as exponential decay (or its opposite, rarely.) (Multiplication in s-space involves both rotation as well as scaling.) So I think jDAQ is accurate in stating that \$\infty\$ is ill-defined here. That said, transfer functions are often examined only for their frequency response, setting \$\sigma=0\$, so that may also be a fair question. But then it's changing the question from Laplace to Fourier, so to speak. I prefer jDAQ's rigorous approach, yet I see the OP specifying "frequency," too. So I'm on the fence about it. – jonk Apr 08 '21 at 19:16
I'm very confused on what is the issue here. The poles and zeros are defined with respect to H(s) even though people plot its bode plot and use frequency responses ( H(jw) ) to analyze and design their circuits. One rough "definition" of poles and zeros using H(jw) would be looking at the bode plot and seeing if at a certain point the slope of the plot changes. But still, an infinity frequency would never "show up" in the bode plot, so it only makes sense to describe what happens as s->infinity (but not s=infinity) or how it behaves as you change one of the poles/zeros->infinity. – jDAQ Apr 08 '21 at 19:56
@user215805 sorry, I didn't get what you mean. But I agree to this definition of poles and zeros https://web.mit.edu/2.14/www/Handouts/PoleZero.pdf . The transfer function will be a ratio of polynomials, the zeros are the roots of the numerator and poles are the roots of the denominators. I Also agree that for a zero \$s_0\$ then \$H(s_0)=0\$ but disagree that \$\lim_{s->\infty} H(s)=0\$ means \$\infty\$ is a zero. Also, if you can point out a specific definition of poles and zeros with respect to just \$j \omega\$ that would be helpful. – jDAQ Apr 08 '21 at 20:03
Hi@jDAQ, even if we do not consider Frequency response ,for S(Z)-domain analysis this is from Wikipedia -"The function f(z) = z has a single pole at infinity of order 1, and a single zero at the origin." https://en.m.wikipedia.org/wiki/Zeros_and_poles – user215805 Apr 08 '21 at 23:07
@user215805 feel free to add your own answer and add all relevant complex analysis results, we clearly are disagreeing on the definitions of poles and zeros and nothing useful will come out of it. – jDAQ Apr 09 '21 at 01:21
@jDAQ, Can you please tell me the difference? I am obviously asking this question theoretically. – sumita sahu Apr 09 '21 at 09:25
