I am little new to electronics and getting some high level overview of digital electronics. The question is that how to know whether addition has been performed in a logic circuit. For example I have a adder and want to add two numbers (say all zero) how can I know whether the calculation has been done. Say I want to save the result in some small flip flop only when the calculations are performed but since the default state of all logic gate is zero and our result is also zero so how can I differentiate between default zero and result of zero.
Asked
Active
Viewed 47 times
2You are supposed to know what the worst case propagation delay is for the longest-time combinatorial path. Then you make sure that your clocking is at least that long. There are some computers that are not clocked, but are asynchronous. But I don't know much about them. – jonk Mar 31 '21 at 00:54
Related question about synchronous logic (and how it relates to propagation delay): https://electronics.stackexchange.com/q/93875/35022 – MarkU Mar 31 '21 at 01:05
https://dspace.library.uvic.ca/bitstream/handle/1828/6986/Alghamdi_Abdulmajeed_MEng_2015.pdf?sequence=3&isAllowed=y – Tony Stewart EE75 Mar 31 '21 at 01:08
Thanks everyone, I was looking for these stuffs! – Mr. Explorer explorer Mar 31 '21 at 07:30
Static timing analysis will tell you. Now learn the static timing analysis tool for the toolchain you are using. – Mar 31 '21 at 16:42
