I have 100 IR photodiodes that I would like to multiplex to one (or the fewest achievable) transimpedance amplifier(s), both for space and price constraints.
I am aware of the capacitance and noise issues due to the distance between the photodiodes and the TIA, explained in this answer.
I am looking for a way to increase the signal to noise ratio. As I am in control of the IR sources, I am wondering if modulating the source as explained here can help filtering some of the noise after the TIA.
However as I am already multiplexing the photodiodes at 100Khz (each photodiode should be read every millisecond), I am not sure of which modulation frequency could be used to help reduce noise, or if it would be achievable at all given that the TIA would need to handle the choosen frequency (its Gain BandWidth Product, and slew rate should be rated accordingly).
Do you think that modulation can be benefical in this case, at which minimal frequency ?
