Can anybody please help me out with how to write test benches for inout ports in Verilog? I can't instantiate them as reg type variables in the test bench.
  • What's the big deal? You will have an inout in TB as well. And you have to drive it from only one side at any given time, either from DUT or TB side. – Mitu Raj Mar 28 '21 at 06:12
  • Does this answer your question? [How to assign value to bidirectional port in verilog?](https://electronics.stackexchange.com/questions/22220/how-to-assign-value-to-bidirectional-port-in-verilog) – Shashank V M Mar 28 '21 at 06:17
You can't drive an inout directly as a reg. inout types need to be wire. So, you need a workaround.
The workaround is creating a driver pin that shares the same wire as the module signal. To do this, define a reg variable for your 3-state test signal, then assign it to the inout pin to connect it.
As follows:
module my_testbench;
wire inout_pin;   // bidirectional signal from DUT
reg inout_drive;  // locally driven value
wire inout_recv;  // locally received value (optional, but models typical pad)
assign inout_pin = inout_drive;
assign inout_recv = inout_pin;
then later in your testbench, you can manipulate the drive state of the tristate pin:
initial begin
inout_drive = 1'bz;    // default high-Z
later....
inout_drive = 1'b0;    // drive a value, propagates onto inout_pin
As you expect, the inout_pin will assume the value you drive it with inout_drive as long as the DUT signal is in high-Z state. Likewise, inout_recv will follow the value driven onto inout_pin.
Strictly speaking, you don't need inout_recv to use the value present on inout_pin in your test bench, but it reflects modeling a tristate I/O pin connected to the DUT.
hacktastical
  • 49,832
  • 47
  • 138
You can test them the same way as you assign them from within the module:
reg dir;
reg gen;
wire bidir;
assign bidir = dir ? gen : 1'bz;
MyAmazingModule DUT (
    .myInOut(bidir)
initial begin
   dir = 0;
   gen = 0;
end
Tom Carpenter
  • 63,168
  • 139
  • 196
