I have a 16 ohm 1.25 ampere 25 watt rheostat that has gone bad. Is it okay to replace it with a 16 ohm 1.7 ampere 50 watt rheostat?
Asked
Active
Viewed 45 times
Bigger is better! – Kartman Mar 23 '21 at 05:12
Using only 1.25 A/ 1.7A means next time it won’t burn out the contacts fast. (Arhennius Law) in theory about 4 times longer and more if used on resistive loads. , but for speakers on high damping ratio power amps limited to 25W. A woofer damping ratio is degraded badly RL/Rs. WD40 comes to mind with 101 uses. – Tony Stewart EE75 Mar 23 '21 at 06:57
Sure, it will last longer! – Lorenzo Marcantonio Mar 23 '21 at 08:58
Why didn’t you say why it / how it failed? How does anyone know how many amps you are using? Maybe you need a 2A rheostat? – Tony Stewart EE75 Mar 23 '21 at 16:30
