I have the circuit shown below and one of the components (Q2) is a common through-hole transistor. I'd like to replace this through hole device 2N3904 with a common SMD transistor that will do the same job so that my PCB manufacturer can solder these for me.
Asked
Active
Viewed 876 times
3asking for part recommendations is off topic here, but why aren't you just using an MMBT3904? – Hearth Mar 22 '21 at 15:28
I understand my thinking was this transistor is so common that many may have the same issue – Feynman137 Mar 22 '21 at 15:31
1Surely you can find the SMD equivalent of a specific transistor without asking here! – Mar 22 '21 at 15:43
MMBT3904 is the same die. You should verify that the thermal performance is adequate, because it won't be as good as a TO-92.
The same part in SMD != doing the same job.
Spehro Pefhany
- 376,485
- 21
- 320
- 842
"the thermal performance [...] won't be as good as a TO-92" certainly makes it sound pitiful. Which I suppose it is! – Hearth Mar 22 '21 at 15:38
@Hearth About 400°C/W compared to 200°C/W (depending on how much copper you spread around the collector lead it could be better though). – Spehro Pefhany Mar 22 '21 at 15:40
I would think an MMBT3904 could be used for anything a sensible designer would use a 2N3904 for, though. I at least would never use a '3904 for anything but switching low currents, due to its extremely poor thermal characteristics. Certainly not anything that would see significant power dissipation. – Hearth Mar 22 '21 at 16:05
1@Hearth People do strange things like [this](https://electronics.stackexchange.com/questions/174223/class-a-single-transistor-amplifier-with-2n3904) – Spehro Pefhany Mar 22 '21 at 16:07
The part is being driven into saturation. Unless the relay is stupidly large, there should be no issue using the SOT-23 part. – hacktastical Mar 22 '21 at 16:13
@hacktastical Correct. To make the answer useful for others though, it's worth noting. I would probably put a beefier transistor in there just on principle, for switching an inductive load. The cost delta is pretty negligible (less than 0.2 cent in 50K). – Spehro Pefhany Mar 22 '21 at 16:14
